Asus Chromebook C300SA- DS02 Keyboard Replacement
    1. Asus Chromebook C300SA- DS02 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Asus Chromebook C300SA- DS02 Keyboard Replacement, Keyboard: step 1, image 2 of 2
      • Power the laptop off and make sure the charger is unplugged before starting.
      • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
      • Remove the three 6.0mm Phillips #0 screws.
      Ask FixBot
    2. Asus Chromebook C300SA- DS02 Keyboard Replacement: step 2, image 1 of 3 Asus Chromebook C300SA- DS02 Keyboard Replacement: step 2, image 2 of 3 Asus Chromebook C300SA- DS02 Keyboard Replacement: step 2, image 3 of 3
      • Open the laptop.
      • Using an iFixit opening tool, pry along the edges of the keyboard.
      • Lift the keyboard and slide it gently towards you.
      • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
      Ask FixBot
    3. Asus Chromebook C300SA- DS02 Keyboard Replacement: step 3, image 1 of 3 Asus Chromebook C300SA- DS02 Keyboard Replacement: step 3, image 2 of 3 Asus Chromebook C300SA- DS02 Keyboard Replacement: step 3, image 3 of 3
      • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
      Ask FixBot
    4. Asus Chromebook C300SA- DS02 Keyboard Replacement: step 4, image 1 of 1
      • Remove the keyboard from the laptop.
      Ask FixBot
Lewis Shabshelowitz
274 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 96
All Time: 971
