Asus Chromebook C300MA-DB01 Mouse Pad Replacement
    1. Asus Chromebook C300MA-DB01 Mouse Pad Replacement, Back Cover: step 1, image 1 of 1
      • Place device bottom-side up.
      Ask FixBot
    2. Asus Chromebook C300MA-DB01 Mouse Pad Replacement: step 2, image 1 of 1
      • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
      • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
      Ask FixBot
    3. Asus Chromebook C300MA-DB01 Mouse Pad Replacement: step 3, image 1 of 1
      • Using a plastic opening tool, separate the bottom case at the seam.
      • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
      Ask FixBot
    4. Asus Chromebook C300MA-DB01 Mouse Pad Replacement: step 4, image 1 of 2 Asus Chromebook C300MA-DB01 Mouse Pad Replacement: step 4, image 2 of 2
      • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
      Ask FixBot
    1. Asus Chromebook C300MA-DB01 Mouse Pad Replacement, Mouse pad: step 5, image 1 of 1
      • Use plastic opening tool to pry open clip holding keyboard wires to the circuit board.
      • Use plastic opening tool to pry open clip holding mouse pad wires to circuit board.
      Ask FixBot
    2. Asus Chromebook C300MA-DB01 Mouse Pad Replacement: step 6, image 1 of 2 Asus Chromebook C300MA-DB01 Mouse Pad Replacement: step 6, image 2 of 2
      • Lift and remove keyboard from device. The keyboard and Mouse pad are one part that must be replaced simultaneously.
      Ask FixBot
wyatt boyatt
541 Reputation
5 Guides authored
USF Tampa, Team S4-G3, Eyestone Fall 2017 Member of USF Tampa, Team S4-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S4G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 395
