Asus Chromebook C300MA-BBCLN12 Keyboard Replacement
    1. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement, Keyboard: step 1, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement, Keyboard: step 1, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement, Keyboard: step 1, image 3 of 3
      • Remove the eight 9.0mm PH00 Phillips screws along the perimeter of the bottom housing.
      • Remove the three 6.0mm PH00 Phillips screws from the center of the bottom housing.
      Ask FixBot
    2. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: step 2, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: step 2, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: step 2, image 3 of 3
      • Separate the palm rest assembly from the bottom housing using the plastic opening tool.
      • It is recommended that you start from a corner and run the tip of the plastic opening tool along the edge of the housing.
      • Lift the palm rest assembly slowly to prevent damaging the two cables connecting it to the motherboard.
      Ask FixBot
    3. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: step 3, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: step 3, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Flip back the hinges on the connectors that secure the wide black cable and the narrow white cable using the tweezers.
      • Disconnect the wide black cable from the motherboard by pulling the blue cable tab straight out of the connector.
      • Disconnect the white ribbon cable from the motherboard by pulling the blue cable tab straight out of the connector.
      Ask FixBot
    4. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: step 4, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: step 4, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: step 4, image 3 of 3
      • Flip back the hinge on the connector that secures the white ribbon cable to the underside of the palm rest assembly using the tweezers.
      • Disconnect the white ribbon cable from the palm rest assembly by pulling the cable straight out of the connector.
      Ask FixBot
    5. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: step 5, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: step 5, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: step 5, image 3 of 3
      • Remove the palm rest assembly from the bottom housing and lay it on a flat surface with the keyboard facing downward.
      • Remove the four 5.0mm PH00 Phillips screws securing the keyboard to the palm rest assembly.
      • Separate the keyboard from the palm rest assembly.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 31
All Time: 700
