Asus Chromebook C300MA-BBCLN12 Display Replacement
    1. Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: step 1, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: step 1, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: step 1, image 3 of 3
      • Wedge the tip of the plastic spudger between the outer display casing and the inner display panel liner.
      • Separate the outer display casing from the inner display panel by sliding the plastic spudger around the perimeter of the display.
      • It is necessary to pull the inner display panel firmly when separating it from the outer display casing along the bottom of the device.
      Ask FixBot
    2. Asus Chromebook C300MA-BBCLN12 Display Replacement: step 2, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Display Replacement: step 2, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Display Replacement: step 2, image 3 of 3
      • Remove the four 3.0mm PH00 screws from the four corners of the display.
      • Grip the edges of the display and tip it forward until it rests on the keyboard.
      • A cable connects the display to the display casing at the bottom. Separate the display panel slowly to prevent damaging the cable.
      Ask FixBot
    3. Asus Chromebook C300MA-BBCLN12 Display Replacement: step 3, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Display Replacement: step 3, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Display Replacement: step 3, image 3 of 3
      • Locate the gold cable connector that attaches the display to the bottom of the display housing.
      • Peel back the protective tape that covers the gold connector.
      • Disconnect the display from the display housing by gripping the sides of the gold display cable connector and pulling away from the bottom of the display.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 454
