Asus Chromebook C300MA DB01 Screen Replacement
    1. Asus Chromebook C300MA DB01 Screen Replacement, Screen: step 1, image 1 of 3 Asus Chromebook C300MA DB01 Screen Replacement, Screen: step 1, image 2 of 3 Asus Chromebook C300MA DB01 Screen Replacement, Screen: step 1, image 3 of 3
      • Use a Jimmy to pry off the hinge cover from the screen.
      Ask FixBot
    2. Asus Chromebook C300MA DB01 Screen Replacement: step 2, image 1 of 2 Asus Chromebook C300MA DB01 Screen Replacement: step 2, image 2 of 2
      • Run the Jimmy along the edges of the screen frame to unsnap it from the connectors.
      • Remove the screen frame manually.
      Ask FixBot
    3. Asus Chromebook C300MA DB01 Screen Replacement: step 3, image 1 of 3 Asus Chromebook C300MA DB01 Screen Replacement: step 3, image 2 of 3 Asus Chromebook C300MA DB01 Screen Replacement: step 3, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the four screws on each corner of the screen.
      • Separate the screen from the top of the Chromebook with the Jimmy.
      • Avoid pulling the screen too far from the device as this can disconnect the wire located at the bottom of the screen.
      • Use the Jimmy to lift the latch on the wire jack.
      • Remove the wires and detach the screen from the device manually.
      Ask FixBot
Earl Gill IV
193 Reputation
2 Guides authored
IUPUI, Team S10-G10, Wilson Spring 2019 Member of IUPUI, Team S10-G10, Wilson Spring 2019
IUPUI-WILSON-S19S10G10
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 21
All Time: 389
