Asus Chromebook C300M USB Port Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
73
All Time:
1,251
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This repair guide will give step-by-step instructions on how to remove the back of the Chromebook to remove and replace the USB Port.
Parts
Tools
    1. Asus Chromebook C300M USB Port Replacement, USB Port: step 1, image 1 of 2 Asus Chromebook C300M USB Port Replacement, USB Port: step 1, image 2 of 2
      • Flip the chromebook on its front.
      • Remove the screws on the back using the Phillips #1 screwdriver.
      • Remove the six 8mm screws.
      • Remove the five 5mm screws.
      Ask FixBot
    2. Asus Chromebook C300M USB Port Replacement: step 2, image 1 of 1
      • Separate the plastic case from the keyboard at the seam using a plastic opening tool.
      Ask FixBot
    3. Asus Chromebook C300M USB Port Replacement: step 3, image 1 of 2 Asus Chromebook C300M USB Port Replacement: step 3, image 2 of 2
      • Fully separate the plastic case from the keyboard by lifting it upward.
      Ask FixBot
    4. Asus Chromebook C300M USB Port Replacement: step 4, image 1 of 2 Asus Chromebook C300M USB Port Replacement: step 4, image 2 of 2
      • The small and wide ribbon cables connect the keyboard to the motherboard.
      • Disconnect the small ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
      • Disconnect the wide ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
      Ask FixBot
    5. Asus Chromebook C300M USB Port Replacement: step 5, image 1 of 2 Asus Chromebook C300M USB Port Replacement: step 5, image 2 of 2
      • Disconnect the USB port in the top right corner from the motherboard.
      • Unplug the the wide ribbon cable using spudger.
      Ask FixBot
    6. Asus Chromebook C300M USB Port Replacement: step 6, image 1 of 2 Asus Chromebook C300M USB Port Replacement: step 6, image 2 of 2
      • Remove the single 3mm screw on the left and bottom side of the USB Port using the Phillips #1 screwdriver.
      • Remove the three 5mm screws on the upper part of the USB port with the same screwdriver.
      • Lift the edge of the white casing. Remove the USB Port by pulling it toward the bottom of the laptop.
      Ask FixBot
2 other people completed this guide.
Rachel Cadle
259 Reputation
2 Guides authored
IUPUI, Team S3-G2, Harley Spring 2019 Member of IUPUI, Team S3-G2, Harley Spring 2019
IUPUI-HARLEY-S19S3G2
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 73
All Time: 1,251
