Asus Chromebook C202SA-YS02 Camera Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
86
All Time:
1,181
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Sometimes your camera can become damaged and need replacing. Note: if your device locates the camera, you may not actually need to replace the hardware. If you do, though, this guide is for you!
Tools
    1. Asus Chromebook C202SA-YS02 Camera Replacement, Bezel: step 1, image 1 of 1
      • Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
      Ask FixBot
    2. Asus Chromebook C202SA-YS02 Camera Replacement: step 2, image 1 of 1
      • Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
      Ask FixBot
    3. Asus Chromebook C202SA-YS02 Camera Replacement: step 3, image 1 of 1
      • Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
      Ask FixBot
    1. Asus Chromebook C202SA-YS02 Camera Replacement, Camera: step 4, image 1 of 1
      • Using the spudger, disconnect the cable from the camera. The camera will then pop out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 86
All Time: 1,181
