Introduction
Go to step 1 ↓This guide will demonstrate how to replace the metal bracket on the Asus Chromebook C202. The bracket may need to be replaced if the Chromebook is heating up unexpectedly or not cooling properly. This is a relatively simple guide to follow. There are many pictures throughout the guide that will aid you in replacing the bracket and show exactly what parts you will need to remove to access the bracket, pay attention to them so as to avoid damaging the laptop or its casing.
Tools
Spudger4.9
Turn the device over so the bottom is facing up.
Remove the ten Phillips #1 8.0 mm screws.
Use a Phillips screwdriver to remove three 4 mm Phillips #1 screws from the metal bracket.
