Asus Chromebook C201 LCD Screen Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
97
All Time:
4,268
Comments: 6
6 comments on steps.
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Chromebook is giving you a blank screen or messed up colors, then this guide will help you replace your screen. While following these steps, be sure to ground yourself. Static can short circuit your Chromebook, so be sure to either wear an anti-static wrist strap or work on a surface that does not generate static electricity, like wood tile.
Tools
    1. Asus Chromebook C201 LCD Screen Replacement, Palm Rest Assembly: step 1, image 1 of 1
      • Flip the laptop upside down with the rear end of the computer away from you.
      Ask FixBot
    2. Asus Chromebook C201 LCD Screen Replacement: step 2, image 1 of 1
      • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
      Ask FixBot
    3. Asus Chromebook C201 LCD Screen Replacement: step 3, image 1 of 1
      • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
      Ask FixBot
    4. Asus Chromebook C201 LCD Screen Replacement: step 4, image 1 of 1
      • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
      Ask FixBot
    5. Asus Chromebook C201 LCD Screen Replacement: step 5, image 1 of 2 Asus Chromebook C201 LCD Screen Replacement: step 5, image 2 of 2
      • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
      Ask FixBot
    6. Asus Chromebook C201 LCD Screen Replacement: step 6, image 1 of 3 Asus Chromebook C201 LCD Screen Replacement: step 6, image 2 of 3 Asus Chromebook C201 LCD Screen Replacement: step 6, image 3 of 3
      • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
      Ask FixBot
    7. Asus Chromebook C201 LCD Screen Replacement: step 7, image 1 of 2 Asus Chromebook C201 LCD Screen Replacement: step 7, image 2 of 2
      • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
      Ask FixBot
    8. Asus Chromebook C201 LCD Screen Replacement: step 8, image 1 of 1
      • Remove the keyboard cover and safely place it somewhere face down.
      Ask FixBot
    1. Asus Chromebook C201 LCD Screen Replacement, LCD Screen: step 9, image 1 of 2 Asus Chromebook C201 LCD Screen Replacement, LCD Screen: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Locate the LCD cable and its connector which is located in the upper left hand corner of the computer. Carefully flip up the tiny tab and safely remove the cable using precision tweezers.
      Ask FixBot
    2. Asus Chromebook C201 LCD Screen Replacement: step 10, image 1 of 2 Asus Chromebook C201 LCD Screen Replacement: step 10, image 2 of 2
      • Disconnect the black and white cables located near the screen hinge.
      Ask FixBot
    3. Asus Chromebook C201 LCD Screen Replacement: step 11, image 1 of 2 Asus Chromebook C201 LCD Screen Replacement: step 11, image 2 of 2
      • Remove the 6, 4mm silver screws from the hinges attaching the LCD to the laptop using the J0 Phillips screwdriver.
      Ask FixBot
    4. Asus Chromebook C201 LCD Screen Replacement: step 12, image 1 of 1
      • Turn the hinges to an upright position.
      Ask FixBot
    5. Asus Chromebook C201 LCD Screen Replacement: step 13, image 1 of 2 Asus Chromebook C201 LCD Screen Replacement: step 13, image 2 of 2
      • Carefully pop the LCD screen assembly out of the laptop case.
      Ask FixBot
    6. Asus Chromebook C201 LCD Screen Replacement: step 14, image 1 of 2 Asus Chromebook C201 LCD Screen Replacement: step 14, image 2 of 2
      • Remove the silver cover.
      • Make sure to put the cover back in right side (longer side) up when re-installing
      Ask FixBot
    7. Asus Chromebook C201 LCD Screen Replacement: step 15, image 1 of 2 Asus Chromebook C201 LCD Screen Replacement: step 15, image 2 of 2
      • Use a blue plastic spudger to snap the LCD cover off, working the spudger around the perimeter and completely remove the cover.
      Ask FixBot
    8. Asus Chromebook C201 LCD Screen Replacement: step 16, image 1 of 1
      • Remove the 4, 3mm silver corner screws holding in the LCD.
      Ask FixBot
    9. Asus Chromebook C201 LCD Screen Replacement: step 17, image 1 of 2 Asus Chromebook C201 LCD Screen Replacement: step 17, image 2 of 2
      • Remove the left hinge by unscrewing the two 3mm large Phillips head screws.
      • Unscrew the one 3mm small Phillips head screw.
      Ask FixBot
    10. Asus Chromebook C201 LCD Screen Replacement: step 18, image 1 of 2 Asus Chromebook C201 LCD Screen Replacement: step 18, image 2 of 2
      • Carefully lift the screen. Gently unravel and unplug the LCD cord.
      Ask FixBot
10 other people completed this guide.
Taylor Allen
327 Reputation
1 Guide authored
USF Tampa, Team 2-51, Cagle Spring 2016 Member of USF Tampa, Team 2-51, Cagle Spring 2016
USFT-CAGLE-S16S2G51
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 97
All Time: 4,268
