Asus Chromebook C101P Screen Replacement
    1. Asus Chromebook C101P Screen Replacement, Keyboard: step 1, image 1 of 1
      • Flip the Chromebook so that the bottom is facing up.
      • Remove the nine T5 Torx screws.
      Ask FixBot
    2. Asus Chromebook C101P Screen Replacement: step 2, image 1 of 1
      • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
      Ask FixBot
    3. Asus Chromebook C101P Screen Replacement: step 3, image 1 of 1
      • Remove the four black screws where the rubber grips were.
      Ask FixBot
    4. Asus Chromebook C101P Screen Replacement: step 4, image 1 of 2 Asus Chromebook C101P Screen Replacement: step 4, image 2 of 2
      • Reorient the Chromebook so the right side is facing upwards.
      • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
      Ask FixBot
    5. Asus Chromebook C101P Screen Replacement: step 5, image 1 of 3 Asus Chromebook C101P Screen Replacement: step 5, image 2 of 3 Asus Chromebook C101P Screen Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
      • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
      • Separate the keyboard from the rest of the laptop.
      Ask FixBot
    1. Asus Chromebook C101P Screen Replacement, Screen: step 6, image 1 of 2 Asus Chromebook C101P Screen Replacement, Screen: step 6, image 2 of 2
      Buy
      • Detach the the screen cables from the motherboard using a pair of tweezers.
      • Peel off the tape or seal to easily remove the screen cables.
      Ask FixBot
    2. Asus Chromebook C101P Screen Replacement: step 7, image 1 of 2 Asus Chromebook C101P Screen Replacement: step 7, image 2 of 2
      • Remove the Phillips 00 screws from the hinges.
      Ask FixBot
    3. Asus Chromebook C101P Screen Replacement: step 8, image 1 of 1
      • Angle the hinge as shown and use a T5 Torx screwdriver to remove the hinge screws.
      Ask FixBot
    4. Asus Chromebook C101P Screen Replacement: step 9, image 1 of 2 Asus Chromebook C101P Screen Replacement: step 9, image 2 of 2
      • Pry open the hinge by using the iFixit opening tool.
      Ask FixBot
    5. Asus Chromebook C101P Screen Replacement: step 10, image 1 of 1
      • Use the iFixit opening tool to pop out the black rubber grips near the bottom of the screen.
      • Use a Phillips 00 screwdriver to remove the screws beneath the rubber grips.
      Ask FixBot
    6. Asus Chromebook C101P Screen Replacement: step 11, image 1 of 3 Asus Chromebook C101P Screen Replacement: step 11, image 2 of 3 Asus Chromebook C101P Screen Replacement: step 11, image 3 of 3
      • Use the iFixit opening tool to pry around the screen.
      • Use the space between the screen and the hinge to prop it up.
      • Once open, slide the wires that are in the hinge out. The screen should now be fully detached from the case.
      Ask FixBot
2 other people completed this guide.
Dan Sysopha
369 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 75
All Time: 2,991
