Asus CM1745 Power Supply Unit Replacement
  1. Asus CM1745 Power Supply Unit Replacement, Powering Off: step 1, image 1 of 1
    • Before opening your desktop PC, make sure to turn it off using the power button.
    • After powering it off, unplug the power cable.
    Ask FixBot
  2. Asus CM1745 Power Supply Unit Replacement, Side Panel: step 2, image 1 of 1
    • Unscrew the 2 Phillips screws as shown.
    • After removing screws, slide the panel off using the handle.
    Ask FixBot
  3. Asus CM1745 Power Supply Unit Replacement, Power Supply: step 3, image 1 of 2 Asus CM1745 Power Supply Unit Replacement, Power Supply: step 3, image 2 of 2
    • Locate the power supply unit which was connected to the cable unplugged in Step 1.
    Ask FixBot
  4. Asus CM1745 Power Supply Unit Replacement, PSU Screws: step 4, image 1 of 1
    • Unscrew Phillips screws from back of the desktop PC.
    Ask FixBot
  5. Asus CM1745 Power Supply Unit Replacement, PSU Cables: step 5, image 1 of 2 Asus CM1745 Power Supply Unit Replacement, PSU Cables: step 5, image 2 of 2
    • Unplug all attached cables from the Power Supply, then unplug the cable attached to the Motherboard inside the PC.
    Ask FixBot
  6. Asus CM1745 Power Supply Unit Replacement, Replacement: step 6, image 1 of 2 Asus CM1745 Power Supply Unit Replacement, Replacement: step 6, image 2 of 2
    • Once unplugged, you can plug in the cables into the new Power Supply and Motherboard.
    Ask FixBot
3 other people completed this guide.
Aaron Stanfield
220 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 62
All Time: 1,465
