Asus CM1745 Hard Drive Replacement
    1. Asus CM1745 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Asus CM1745 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
      • Remove the sidepanel by unscrewing the two screws fastening the panel on the rear. Once unscrewed, slide the panel towards the rear until it releases then lift away.
      • Remember to unplug the device before beginning disassembly, to make sure that no power is running through the device during repair. You could risk hurting yourself and/or damage sensitive components.
      Ask FixBot
    2. Asus CM1745 Hard Drive Replacement: step 2, image 1 of 2 Asus CM1745 Hard Drive Replacement: step 2, image 2 of 2
      • Remove the two cables from the rear of the Hard Drive.
      • Unscrew the two screws attached to the Hard Drive with a Phillips #0 screwdriver.
      Ask FixBot
    3. Asus CM1745 Hard Drive Replacement: step 3, image 1 of 3 Asus CM1745 Hard Drive Replacement: step 3, image 2 of 3 Asus CM1745 Hard Drive Replacement: step 3, image 3 of 3
      • Flip the computer over and remove the sidepanel on that side.
      • Remove the Phillips #0 screw(s) attached to the Hard Drive on this side.
      • Once removed, slide the Hard Drive out the back. Remember the orientation that the Hard Drive was in.
      Ask FixBot
    4. Asus CM1745 Hard Drive Replacement: step 4, image 1 of 3 Asus CM1745 Hard Drive Replacement: step 4, image 2 of 3 Asus CM1745 Hard Drive Replacement: step 4, image 3 of 3
      • Take your replacement Hard Drive (Picture does not necessarily represent the exact Hard Drive) and place it in the same slot as the old one.
      • Replace the two screws on the front of the cage and the screw(s) on the back.
      • Replace the power and data cables on the back of the hard drive.
      Ask FixBot
If everything looks to be in the right place, you should be able to boot the computer and boot into the BIOS to check if the Hard Drive is recognized. You will have to install a new Windows installation if this Hard Drive was your only Hard Drive.
2 other people completed this guide.
TC Fowlar
896 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 70
All Time: 4,574
