Up to 20% off select tools
Asus CM1745 CPU Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
136
All Time:
3,359
Comments: 0
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Parts
Tools
Introduction
Go to step 1 ↓
The following replacement guide details how to properly replace the Asus CM1745 CPU.  Because this involves replacing internal parts of your computer, this could void any remaining warranty.  The first part of this guide details how to remove the heatsink. The second part covers removing and replacing the CPU itself.  Before beginning, please make sure that your PC is powered off and disconnected from the wall. Additionally, make sure you’re careful with the CPU, as it is incredibly fragile.
    1. Asus CM1745 CPU Replacement, Heatsink: step 1, image 1 of 2 Asus CM1745 CPU Replacement, Heatsink: step 1, image 2 of 2
      • Remove the sidepanel by unscrewing the two screws fastening the panel on the rear. Once unscrewed, slide the panel towards the rear until it releases then lift away.
      Ask FixBot
    2. Asus CM1745 CPU Replacement: step 2, image 1 of 2 Asus CM1745 CPU Replacement: step 2, image 2 of 2
      • Unplug the CPU fan connector from the motherboard.
      • Then open the latch under the CPU fan and unhook the metal fasteners.
      • Lift the CPU heatsink and cable off of the CPU carefully.
      Ask FixBot
    3. Asus CM1745 CPU Replacement: step 3, image 1 of 3 Asus CM1745 CPU Replacement: step 3, image 2 of 3 Asus CM1745 CPU Replacement: step 3, image 3 of 3
      • Clean both the CPU top and the heatsink bottom by slightly moistening a paper towel with rubbing alcohol and rubbing lightly.
      • Grab your thermal paste and put a pea-sized amount in the middle of the CPU top.
      • Gently replace the heatsink on top of the CPU and re-lock the heatsink fasteners.
      • Replug the CPU Fan connector to the motherboard header.
      • Check out the How to Apply Thermal Paste guide for more details and best practices.
      Ask FixBot
    1. Asus CM1745 CPU Replacement, CPU: step 4, image 1 of 3 Asus CM1745 CPU Replacement, CPU: step 4, image 2 of 3 Asus CM1745 CPU Replacement, CPU: step 4, image 3 of 3
      • Remove CPU Heatsink to expose CPU.
      • Open the silver retention bar of the CPU by pulling the bar out of the plastic hook and hinging it open.
      • Remembering the orientation of the CPU, carefully pull the CPU out of the socket.
      Ask FixBot
    2. Asus CM1745 CPU Replacement: step 5, image 1 of 3 Asus CM1745 CPU Replacement: step 5, image 2 of 3 Asus CM1745 CPU Replacement: step 5, image 3 of 3
      • Take your replacement CPU and line up the arrows marked in the photos.
      • Place the CPU in the socket and gently massage the top of the cpu to ensure that there is no wiggle.
      • If the CPU feels secure, pull the retention bar back into place.
      • Place new thermal paste onto the CPU and replace the heatsink.
      Ask FixBot
If everything looks correct, boot the computer up. It may take a few minutes to fully boot as the motherboard recognizes the new hardware.
8 other people completed this guide.
Author
with
TC Fowlar
959 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 136
All Time: 3,359
