Up to 20% off select tools
Asus A53U-ES21 RAM Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
70
All Time:
1,127
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 4 - 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The RAM of your computer acts as the computer's "working" memory. The operating system and every program, application, and process requires memory to operate. The more memory your computer has available, generally speaking, the more it can do at once. Replacing your Asus A53U-ES21's RAM with faster and larger memory can noticeably improve its performance.
    1. Asus A53U-ES21 RAM Replacement, Battery: step 1, image 1 of 2 Asus A53U-ES21 RAM Replacement, Battery: step 1, image 2 of 2
      • Make sure the laptop is off.
      • Flip the laptop upside down so that the battery is facing you.
      Ask FixBot
    2. Asus A53U-ES21 RAM Replacement: step 2, image 1 of 2 Asus A53U-ES21 RAM Replacement: step 2, image 2 of 2
      • Move the two sliders towards the outer edge of the laptop.
      • Pull the battery out with your left hand while holding the right slider.
      Ask FixBot
    1. Asus A53U-ES21 RAM Replacement, RAM: step 3, image 1 of 2 Asus A53U-ES21 RAM Replacement, RAM: step 3, image 2 of 2
      • Remove the 5mm screw holding the RAM panel in place with a Phillips #1 screwdriver.
      Ask FixBot
    2. Asus A53U-ES21 RAM Replacement: step 4, image 1 of 2 Asus A53U-ES21 RAM Replacement: step 4, image 2 of 2
      • Remove the panel using the plastic opening tools.
      • Slide the tool along the edge to release the multiple catches keeping it secure.
      Ask FixBot
    3. Asus A53U-ES21 RAM Replacement: step 5, image 1 of 3 Asus A53U-ES21 RAM Replacement: step 5, image 2 of 3 Asus A53U-ES21 RAM Replacement: step 5, image 3 of 3
      • Use plastic opening tools to move the metal clips holding the RAM in place outwards.
      Ask FixBot
    4. Asus A53U-ES21 RAM Replacement: step 6, image 1 of 1
      • Gently pull the RAM out of its slot.
      Ask FixBot
Author
with
Kenae Brooks
252 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 70
All Time: 1,127
