Asus A53U-ES21 Hard Drive Replacement
    1. Asus A53U-ES21 Hard Drive Replacement, Battery: step 1, image 1 of 2 Asus A53U-ES21 Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Make sure the laptop is off.
      • Flip the laptop upside down so that the battery is facing you.
      Ask FixBot
    2. Asus A53U-ES21 Hard Drive Replacement: step 2, image 1 of 2 Asus A53U-ES21 Hard Drive Replacement: step 2, image 2 of 2
      • Move the two sliders towards the outer edge of the laptop.
      • Pull the battery out with your left hand while holding the right slider.
      Ask FixBot
    1. Asus A53U-ES21 Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Asus A53U-ES21 Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
      • Remove the 5mm screw using a Phillips #1 screwdriver.
      • Use the iFixit opening tools to remove the hard drive panel.
      Ask FixBot
    2. Asus A53U-ES21 Hard Drive Replacement: step 4, image 1 of 2 Asus A53U-ES21 Hard Drive Replacement: step 4, image 2 of 2
      • Pull upwards on the black ribbon on the end of the hard drive.
      • Pull the hard drive out from its socket and remove it from the device.
      Ask FixBot
Chase Poirier
585 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 67
All Time: 921
