Up to 20% off select tools
Asus A53S RAM Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
99
All Time:
1,794
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will help you replace the RAM in an Asus A53S.
Random-Access Memory (RAM) stores the short-term data that the laptop needs to operate properly.
Before using this guide, make sure to review the troubleshooting page.
If your laptop is running slow, you may want to upgrade your RAM. The Asus A53S can be upgraded to up to 8GB of memory.
Make sure to power off your laptop completely, disconnect from any external power source, and remove the battery before beginning the process.
    1. Asus A53S RAM Replacement, RAM: step 1, image 1 of 3 Asus A53S RAM Replacement, RAM: step 1, image 2 of 3 Asus A53S RAM Replacement, RAM: step 1, image 3 of 3
      • Power off your device and remove the battery before beginning this guide.
      • Flip your laptop so the underside is facing up.
      • Using a Phillips #01 screwdriver, unscrew the two 6 mm screws at the indicated places.
      • Remove the back plate.
      Ask FixBot
    2. Asus A53S RAM Replacement: step 2, image 1 of 3 Asus A53S RAM Replacement: step 2, image 2 of 3 Asus A53S RAM Replacement: step 2, image 3 of 3
      • Gently push the metal clips apart, allowing the RAM to pop up.
      • Remove the top RAM.
      Ask FixBot
    3. Asus A53S RAM Replacement: step 3, image 1 of 2 Asus A53S RAM Replacement: step 3, image 2 of 2
      • Remove the bottom RAM.
      Ask FixBot
2 other people completed this guide.
Author
with
Laurie Medina
671 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 99
All Time: 1,794
