Asus A53S Optical Drive Replacement
    1. Asus A53S Optical Drive Replacement, Optical Drive: step 1, image 1 of 3 Asus A53S Optical Drive Replacement, Optical Drive: step 1, image 2 of 3 Asus A53S Optical Drive Replacement, Optical Drive: step 1, image 3 of 3
      • Power off your device and remove the battery before beginning this guide.
      • Open the laptop.
      • Using the Spudger, insert the flat end into the notches at the top of the keyboard and slowly "pop" the keyboard up and out of the device.
      Ask FixBot
    2. Asus A53S Optical Drive Replacement: step 2, image 1 of 2 Asus A53S Optical Drive Replacement: step 2, image 2 of 2
      • Using the flat end of the spudger, lift the black lock bard on the ZIF connector and disconnect the keyboard from the computer.
      • Remove the keyboard.
      Ask FixBot
    3. Asus A53S Optical Drive Replacement: step 3, image 1 of 2 Asus A53S Optical Drive Replacement: step 3, image 2 of 2
      • Remove the single 6 mm screw using the Phillips #1 screwdriver.
      Ask FixBot
    4. Asus A53S Optical Drive Replacement: step 4, image 1 of 1
      • Pull out the optical drive.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 29
Past 30 Days: 86
All Time: 684
