Asus A52F XE2 Lower Case Replacement
    1. Asus A52F XE2 Lower Case Replacement, Battery: step 1, image 1 of 2 Asus A52F XE2 Lower Case Replacement, Battery: step 1, image 2 of 2
      • Place the laptop face down with the battery facing away from you.
      • Locate the two buttons next to the battery.
      • Slide the right slider to the unlocked (red) position.
      Ask FixBot
    2. Asus A52F XE2 Lower Case Replacement: step 2, image 1 of 2 Asus A52F XE2 Lower Case Replacement: step 2, image 2 of 2
      • Hold the left button to the left.
      • Slide the battery with your other hand away from you and it should disconnect.
      Ask FixBot
    1. Asus A52F XE2 Lower Case Replacement, Lower Case: step 3, image 1 of 3 Asus A52F XE2 Lower Case Replacement, Lower Case: step 3, image 2 of 3 Asus A52F XE2 Lower Case Replacement, Lower Case: step 3, image 3 of 3
      • Remove the five Phillips # 0 screws from the back panel.
      • Using your finger or a plastic spudger start to carefully pry up the back planel.
      Ask FixBot
    2. Asus A52F XE2 Lower Case Replacement: step 4, image 1 of 2 Asus A52F XE2 Lower Case Replacement: step 4, image 2 of 2
      • Slide the back panel away and remove the panel.
      Ask FixBot
2 other people completed this guide.
Michael Benson
179 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 109
All Time: 847
