Up to 20% off select tools
Asus A52F Screen Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
94
All Time:
1,906
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a cracked or malfunctioning screen of your A52F-XE2 laptop. If the screen of your laptop has physical damage such as cracks, breaks, faulty CCFL (back-light), a dim or flickering screen, dead pixels, or vertical/horizontal lines on the screen, it may need to be replaced since it can prevent the screen from displaying. Before following this guide, make sure your laptop is completely powered off and any external power sources are disconnected.
    1. Asus A52F Screen Replacement, Screen: step 1, image 1 of 2 Asus A52F Screen Replacement, Screen: step 1, image 2 of 2
      • Remove the six rubber pads around the border of the screen using a spudger.
      Ask FixBot
    2. Asus A52F Screen Replacement: step 2, image 1 of 1
      • Remove the six screws using a Phillips #0 screwdriver.
      Ask FixBot
    3. Asus A52F Screen Replacement: step 3, image 1 of 2 Asus A52F Screen Replacement: step 3, image 2 of 2
      • Separate the plastic bezel from the rest of the screen using an opening tool.
      Ask FixBot
    4. Asus A52F Screen Replacement: step 4, image 1 of 2 Asus A52F Screen Replacement: step 4, image 2 of 2
      • Lift the metal bar on the top of the screen away from the device.
      Ask FixBot
    5. Asus A52F Screen Replacement: step 5, image 1 of 3 Asus A52F Screen Replacement: step 5, image 2 of 3 Asus A52F Screen Replacement: step 5, image 3 of 3
      • Gently detach the wire to the left of the webcam.
      Ask FixBot
    6. Asus A52F Screen Replacement: step 6, image 1 of 2 Asus A52F Screen Replacement: step 6, image 2 of 2
      • Carefully pull the screen toward you and lay it on the keyboard.
      • Peel the webcam wire off the back of the screen.
      Ask FixBot
    7. Asus A52F Screen Replacement: step 7, image 1 of 3 Asus A52F Screen Replacement: step 7, image 2 of 3 Asus A52F Screen Replacement: step 7, image 3 of 3
      • Peel back the tape holding the screen cable in its socket.
      • Gently pull the tape and cable away from you to remove the cable from the socket.
      • The screen is now disconnected and can be removed.
      Ask FixBot
2 other people completed this guide.
Author
with
Morgan Hays
399 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 94
All Time: 1,906
