Asus A52F Hard Drive Replacement
    1. Asus A52F Hard Drive Replacement, Battery: step 1, image 1 of 2 Asus A52F Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Place the laptop face down with the battery facing away from you.
      • Locate the two buttons next to the battery.
      • Slide the right slider to the unlocked (red) position.
      Ask FixBot
    2. Asus A52F Hard Drive Replacement: step 2, image 1 of 2 Asus A52F Hard Drive Replacement: step 2, image 2 of 2
      • Hold the left button to the left.
      • Slide the battery with your other hand away from you and it should disconnect.
      Ask FixBot
    1. Asus A52F Hard Drive Replacement, Lower Case: step 3, image 1 of 3 Asus A52F Hard Drive Replacement, Lower Case: step 3, image 2 of 3 Asus A52F Hard Drive Replacement, Lower Case: step 3, image 3 of 3
      • Remove the five Phillips # 0 screws from the back panel.
      • Using your finger or a plastic spudger start to carefully pry up the back planel.
      Ask FixBot
    2. Asus A52F Hard Drive Replacement: step 4, image 1 of 2 Asus A52F Hard Drive Replacement: step 4, image 2 of 2
      • Slide the back panel away and remove the panel.
      Ask FixBot
    1. Asus A52F Hard Drive Replacement, Hard Drive: step 5, image 1 of 3 Asus A52F Hard Drive Replacement, Hard Drive: step 5, image 2 of 3 Asus A52F Hard Drive Replacement, Hard Drive: step 5, image 3 of 3
      • Remove the four Phillips #0 screws holding the hard drive case to the laptop.
      • Lift the hard drive upwards by the two arms in order to remove the hard drive case from the laptop.
      Ask FixBot
    2. Asus A52F Hard Drive Replacement: step 6, image 1 of 2 Asus A52F Hard Drive Replacement: step 6, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the cage screws on the side of the hard drive.
      Ask FixBot
    3. Asus A52F Hard Drive Replacement: step 7, image 1 of 2 Asus A52F Hard Drive Replacement: step 7, image 2 of 2
      • Next, slide the case off of the broken hard drive.
      • Slide the working hard drive into the case and screw it on.
      Ask FixBot
3 other people completed this guide.
Roman Justice
255 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 115
All Time: 2,316
