Asus A52F Cooling System Replacement
    1. Asus A52F Cooling System Replacement, Battery: step 1, image 1 of 2 Asus A52F Cooling System Replacement, Battery: step 1, image 2 of 2
      • Place the laptop face down with the battery facing away from you.
      • Locate the two buttons next to the battery.
      • Slide the right slider to the unlocked (red) position.
      Ask FixBot
    2. Asus A52F Cooling System Replacement: step 2, image 1 of 2 Asus A52F Cooling System Replacement: step 2, image 2 of 2
      • Hold the left button to the left.
      • Slide the battery with your other hand away from you and it should disconnect.
      Ask FixBot
    1. Asus A52F Cooling System Replacement, Lower Case: step 3, image 1 of 3 Asus A52F Cooling System Replacement, Lower Case: step 3, image 2 of 3 Asus A52F Cooling System Replacement, Lower Case: step 3, image 3 of 3
      • Remove the five Phillips # 0 screws from the back panel.
      • Using your finger or a plastic spudger start to carefully pry up the back planel.
      Ask FixBot
    2. Asus A52F Cooling System Replacement: step 4, image 1 of 2 Asus A52F Cooling System Replacement: step 4, image 2 of 2
      • Slide the back panel away and remove the panel.
      Ask FixBot
    1. Asus A52F Cooling System Replacement, Cooling System: step 5, image 1 of 2 Asus A52F Cooling System Replacement, Cooling System: step 5, image 2 of 2
      • Removal of cooling system will void your warranty. Proceed with caution.
      Ask FixBot
    2. Asus A52F Cooling System Replacement: step 6, image 1 of 2 Asus A52F Cooling System Replacement: step 6, image 2 of 2
      • Using a Phillips #0 screwdriver, remove all six screws from the cooling system.
      • Unplug the fan power connector.
      Ask FixBot
    3. Asus A52F Cooling System Replacement: step 7, image 1 of 2 Asus A52F Cooling System Replacement: step 7, image 2 of 2
      • Carefully grab the copper pipe and start to lift upward.
      • Lift to the angle shown and then start to slide it out.
      Ask FixBot
    4. Asus A52F Cooling System Replacement: step 8, image 1 of 1
      • Clean the designated area with isopropyl alcohol on a microfiber cloth
      • Replace with new thermal paste if needed
      Ask FixBot
3 other people completed this guide.
Bradley Varnum
345 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 115
All Time: 1,468
