Up to 20% off select tools
Asus A4110 Disassembly
Views: 6.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
36
Past 30 Days:
169
All Time:
6,096
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 20 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Asus A4110 Disassembly, Open case: step 1, image 1 of 2 Asus A4110 Disassembly, Open case: step 1, image 2 of 2
      • Remove screws at the circles
      • Remove gum strap and screw 5 screws out
      • Use a big screwdriver or some plastic to softly open the entire case around, starting at one down corner where your removed the screws before. The plastic clips will click a little. Don't be to hard.
      • Then you can lay the back next to the front, see second picture.
      Ask FixBot
    2. Asus A4110 Disassembly: step 2, image 1 of 1
      • You can now remove and/or replace harddrive easily. (This can be done in later steps, but will be necessary before attempting to move the motherboard)
      • If you're only replacing the drive, then you're done here. Retrace your steps to get the device back to and assembled product.
      • If you are replacing or fixing something else as well, please continue with the steps.
      Ask FixBot
    3. Asus A4110 Disassembly: step 3, image 1 of 2 Asus A4110 Disassembly: step 3, image 2 of 2
      • Remove VESA mount by 4 screws
      • Remove mainboard blend by 9 screws afterwards.
      Ask FixBot
    4. Asus A4110 Disassembly: step 4, image 1 of 1
      • If you brought one, use a marker and mark one of the cable to more easily distinguis them.
      • (Remember which goes where!)
      • Remove the antenna cables from the Wi-Fi Module.
      • Remove the 2 screws to unfasten the Wi-Fi Module, then angle it upwards and pull it out, away from the socket to continue disassembly.
      Ask FixBot
    5. Asus A4110 Disassembly: step 5, image 1 of 3 Asus A4110 Disassembly: step 5, image 2 of 3 Asus A4110 Disassembly: step 5, image 3 of 3
      • Remove display cables by pulling the white plastic clip up from the cable side
      • Pull up the left clip same as the right one from first picture from cable side.
      • Then the touch connector (middle) must be opened from board side up, be patient and watch out for this, else your connector might brake!
      Ask FixBot
    6. Asus A4110 Disassembly: step 6, image 1 of 1
      • This is how the connectors should now look like, see the marked position of the plastic strips.
      Ask FixBot
    7. Asus A4110 Disassembly: step 7, image 1 of 1
      • Remove further connectors for USB, power, sound and keys.
      Ask FixBot
    8. Asus A4110 Disassembly: step 8, image 1 of 2 Asus A4110 Disassembly: step 8, image 2 of 2
      • Now remove 9 screws and the cooling screw to remove the mainboard.
      Ask FixBot
Author
with
Max
175 Reputation
1 Guide authored
1 Guide Comment
grazie della spiegazione
Pierluigi Ricco - Reply Share
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 169
All Time: 6,096
