Asus A3H Thermal Paste Replacement
    1. Asus A3H Thermal Paste Replacement, Opening the back panel.: step 1, image 1 of 3 Asus A3H Thermal Paste Replacement, Opening the back panel.: step 1, image 2 of 3 Asus A3H Thermal Paste Replacement, Opening the back panel.: step 1, image 3 of 3
      • Unscrew the 3 screws holding the CPU cover in place.
      • Unscrew the 4 screws holding the CPU heatsink.
      Ask FixBot
    2. Asus A3H Thermal Paste Replacement, Replacing the thermal paste.: step 2, image 1 of 3 Asus A3H Thermal Paste Replacement, Replacing the thermal paste.: step 2, image 2 of 3 Asus A3H Thermal Paste Replacement, Replacing the thermal paste.: step 2, image 3 of 3
      • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
      • Don`t use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
      • Last, put the heatsink back carefully and tighten the screws in order 1 -> 4 to ensure even pressure.
      Ask FixBot
3 other people completed this guide.
Simeon Brankov
10,510 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 100
All Time: 1,316
