Astro Mixamp USB Port Replacement
Views: 9.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
116
All Time:
9,056
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
Use when the USB port needs to be removed. (Soldering Required)
Tools
    1. Astro Mixamp USB Port Replacement, Panel Dial: step 1, image 1 of 2 Astro Mixamp USB Port Replacement, Panel Dial: step 1, image 2 of 2
      • Grip the dial tightly and pull straight off the device.
      • Repeat for the second dial
      Ask FixBot
    2. Astro Mixamp USB Port Replacement: step 2, image 1 of 2 Astro Mixamp USB Port Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, remove the spacer nuts and washers from each dial post.
      Ask FixBot
    1. Astro Mixamp USB Port Replacement, Outer Casing: step 3, image 1 of 2 Astro Mixamp USB Port Replacement, Outer Casing: step 3, image 2 of 2
      • Before opening your device, ensure the device is not on or connected to the charging cable.
      • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
      • Pull the rubber foot free of the plastic casing.
      Ask FixBot
    2. Astro Mixamp USB Port Replacement: step 4, image 1 of 1
      • Use a screwdriver to remove the screw from the rear casing.
      Ask FixBot
    3. Astro Mixamp USB Port Replacement: step 5, image 1 of 1
      • Gently lift the rear casing from the device.
      Ask FixBot
    1. Astro Mixamp USB Port Replacement, Motherboard: step 6, image 1 of 3 Astro Mixamp USB Port Replacement, Motherboard: step 6, image 2 of 3 Astro Mixamp USB Port Replacement, Motherboard: step 6, image 3 of 3
      • Remove the four screws that hold the motherboard in place.
      • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
      Ask FixBot
    2. Astro Mixamp USB Port Replacement: step 7, image 1 of 1
      • Gently pull the motherboard from the front cover.
      Ask FixBot
    1. Astro Mixamp USB Port Replacement, USB Port: step 8, image 1 of 3 Astro Mixamp USB Port Replacement, USB Port: step 8, image 2 of 3 Astro Mixamp USB Port Replacement, USB Port: step 8, image 3 of 3
      • Press the tip of a hot soldering iron to the USB connection to melt the solder.
      • Use a nylon spudger to lift the USB from the solder.
      • Repeat for each of the four USB connections.
      • For more help on soldering, refer to this guide: How To Solder and Desolder Connections
      Ask FixBot
2 other people completed this guide.
Hope Burns
769 Reputation
5 Guides authored
4 Guide Comments
What port is used as a replacement?
jonescoleman1738 - Reply Share
Did you ever identify an appropriate replacement port?
Lepec - Reply Share
something was broken out of the port of the USB connection
MoreZemtor - Reply Share
Will this method work with the 2015 tr mixamp?
jeffreyalvarez9 - Reply Share
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 116
All Time: 9,056
