Astro Mixamp Control Button Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
106
All Time:
2,265
Comments: 2
2 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove control buttons for cleaning or replacement.
Tools
    1. Astro Mixamp Control Button Replacement, Panel Dial: step 1, image 1 of 2 Astro Mixamp Control Button Replacement, Panel Dial: step 1, image 2 of 2
      • Grip the dial tightly and pull straight off the device.
      • Repeat for the second dial
      Ask FixBot
    2. Astro Mixamp Control Button Replacement: step 2, image 1 of 2 Astro Mixamp Control Button Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, remove the spacer nuts and washers from each dial post.
      Ask FixBot
    1. Astro Mixamp Control Button Replacement, Outer Casing: step 3, image 1 of 2 Astro Mixamp Control Button Replacement, Outer Casing: step 3, image 2 of 2
      • Before opening your device, ensure the device is not on or connected to the charging cable.
      • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
      • Pull the rubber foot free of the plastic casing.
      Ask FixBot
    2. Astro Mixamp Control Button Replacement: step 4, image 1 of 1
      • Use a screwdriver to remove the screw from the rear casing.
      Ask FixBot
    3. Astro Mixamp Control Button Replacement: step 5, image 1 of 1
      • Gently lift the rear casing from the device.
      Ask FixBot
    1. Astro Mixamp Control Button Replacement, Motherboard: step 6, image 1 of 3 Astro Mixamp Control Button Replacement, Motherboard: step 6, image 2 of 3 Astro Mixamp Control Button Replacement, Motherboard: step 6, image 3 of 3
      • Remove the four screws that hold the motherboard in place.
      • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
      Ask FixBot
    2. Astro Mixamp Control Button Replacement: step 7, image 1 of 1
      • Gently pull the motherboard from the front cover.
      Ask FixBot
    1. Astro Mixamp Control Button Replacement, Control Button: step 8, image 1 of 2 Astro Mixamp Control Button Replacement, Control Button: step 8, image 2 of 2
      • Gently insert a metal spudger under a control button housing.
      • Do not pry the button housing from the front panel, this can cause damage to the button.
      • Rotate the control button around the marked pin.
      Ask FixBot
3 other people completed this guide.
Hope Burns
769 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 106
All Time: 2,265
