Up to 20% off select tools
Astro A50 Motherboard Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
119
All Time:
5,060
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
The guide allows for you to take apart and replace the channel selection switch on an Astro A50 gaming headset with only a Phillips head screwdriver.
    1. Astro A50 Motherboard Replacement, Secondary Motherboard: step 1, image 1 of 2 Astro A50 Motherboard Replacement, Secondary Motherboard: step 1, image 2 of 2
      • Remove the foam ear padding by pulling it straight to you
      Ask FixBot
    2. Astro A50 Motherboard Replacement: step 2, image 1 of 1
      • Remove the four 3.5mm Phillips head screws circled in red, and remove the grey cover
      Ask FixBot
    3. Astro A50 Motherboard Replacement: step 3, image 1 of 1
      • Remove the four 3.5mm Phillips head screws circled in red and remove the silver cover.
      Ask FixBot
    4. Astro A50 Motherboard Replacement: step 4, image 1 of 2 Astro A50 Motherboard Replacement: step 4, image 2 of 2
      • Remove the motherboard remove the four 3.5mm long Phillips head screws circled in red.
      • Remove the 3.5mm Phillips head screw circled in blue to remove secondary motherboard.
      Ask FixBot
    5. Astro A50 Motherboard Replacement: step 5, image 1 of 1
      • Separate the secondary mother board from the motherboard by pulling firmly to the right on the white connector.
      Ask FixBot
Author
with
William Czerwonka
228 Reputation
2 Guides authored
IUPUI, Team S1-G1, Baechle Fall 2017 Member of IUPUI, Team S1-G1, Baechle Fall 2017
IUPUI-BAECHLE-F17S1G1
2 Members
36 Guides authored
1 Guide Comment
Estaría bien uno pero de la placa del centro de carga y saber dónde se puede conseguir, saludos
Menoalf07 - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 119
All Time: 5,060
