Astro A50 2016 Headset Speakers Replacement
  1. Astro A50 2016 Headset Speakers Replacement, Headset Speakers: step 1, image 1 of 2 Astro A50 2016 Headset Speakers Replacement, Headset Speakers: step 1, image 2 of 2
    • Remove the magnetic ear pads by gently pulling them away from the headset. Be careful not to remove the left earpad, which houses the microphone, and ensure you're only removing the right earpad.
  2. Astro A50 2016 Headset Speakers Replacement: step 2, image 1 of 1
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016 Headset Speakers Replacement: step 3, image 1 of 1
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016 Headset Speakers Replacement: step 4, image 1 of 1
    • Lift the speaker module up off the device.
6 other people completed this guide.
Vincent Seguin
382 Reputation
3 Guides authored
Cal Poly, Team S15-G1, Livingston Fall 2017 Member of Cal Poly, Team S15-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G1
3 Members
13 Guides authored
5 Guide Comments
Great, pictures and explaining. But where do i get an speaker to replace the old one?
D3EW D - Reply Share
I am also looking for the replacement speakers. They seem impossible to find
Steven Fleck - Reply Share
hola me encantaria que me pudieran decir donde comprar el repuesto de uno de los altavocez, porque no encuentro nada
ruben el gay - Reply Share
Awesome, but I don’t believe see anywhere on how to fix the mic as it rotates 360 free spinning rather than locking in the 90° talk and mute positions…?
Tippio - Reply Share
this is almost no solution, your cover is broken, there is stop on plastic cover.
X Pi Acoustic(CN) - Reply Share
Past 24 Hours: 1
Past 7 Days: 31
Past 30 Days: 108
All Time: 7,879
