Astro A50 2016 Base Station Motherboard Replacement
  1. Astro A50 2016 Base Station Motherboard Replacement, Base Station Motherboard: step 1, image 1 of 1
    • Remove the four rubber feet from the bottom of the base station using the plastic opening tool.
    Ask FixBot
  2. Astro A50 2016 Base Station Motherboard Replacement: step 2, image 1 of 1
    • Remove the ten 6 mm screws using a T8 screwdriver.
    Ask FixBot
  3. Astro A50 2016 Base Station Motherboard Replacement: step 3, image 1 of 2 Astro A50 2016 Base Station Motherboard Replacement: step 3, image 2 of 2
    • Remove the four 6 mm screws using a T6 screwdriver.
    • Remove each metal plate by lodging the plastic opening tool underneath it and using your hands to lift the plate away from the device.
    Ask FixBot
  4. Astro A50 2016 Base Station Motherboard Replacement: step 4, image 1 of 2 Astro A50 2016 Base Station Motherboard Replacement: step 4, image 2 of 2
    • Use your hand to gently pull the green side plates away from the center of the device.
    Ask FixBot
  5. Astro A50 2016 Base Station Motherboard Replacement: step 5, image 1 of 1
    • Remove the six 6mm screws using a T6 screwdriver.
    Ask FixBot
  6. Astro A50 2016 Base Station Motherboard Replacement: step 6, image 1 of 3 Astro A50 2016 Base Station Motherboard Replacement: step 6, image 2 of 3 Astro A50 2016 Base Station Motherboard Replacement: step 6, image 3 of 3
    • Lift up the motherboard from the base station and pull it away from the device to remove it.
    Ask FixBot
2 other people completed this guide.
Vincent Seguin
382 Reputation
3 Guides authored
Cal Poly, Team S15-G1, Livingston Fall 2017 Member of Cal Poly, Team S15-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G1
3 Members
13 Guides authored
5 Guide Comments
my base station dont turen on, the front leds. any solution?
edgar jesus cortez cosio - Reply Share
my base station dont turns on the front leds, any solution?
having the same problem {with the front LEDs not turning on or it not being recognized by pc}what does the white button on the base station motherboard do?
Devin Danimals - Reply Share
Where can I purchase one of these motherboards?
he-g-man-aftermath - Reply Share
I need a new base board any ideas where I may purchase one
Paul Bishop - Reply Share
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 110
All Time: 11,089
