Up to 20% off select tools
Astro A50 2016 Headset Battery Replacement
Views: 33K
View statistics:
Past 24 Hours:
9
Past 7 Days:
69
Past 30 Days:
322
All Time:
33,285
Comments: 22
7 comments on steps, 15 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
The battery is what gives the headset the power to run and function. This guide will show you how to remove the battery from the headset.
    1. Astro A50 2016  Headset Battery Replacement, Headset Speakers: step 1, image 1 of 2 Astro A50 2016  Headset Battery Replacement, Headset Speakers: step 1, image 2 of 2
      • Remove the magnetic ear pads by gently pulling them away from the headset. Be careful not to remove the left earpad, which houses the microphone, and ensure you're only removing the right earpad.
      Ask FixBot
    2. Astro A50 2016  Headset Battery Replacement: step 2, image 1 of 1
      • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
      Ask FixBot
    3. Astro A50 2016  Headset Battery Replacement: step 3, image 1 of 1
      • Remove the four 6mm Phillips 1 screws.
      Ask FixBot
    4. Astro A50 2016  Headset Battery Replacement: step 4, image 1 of 1
      • Lift the speaker module up off the device.
      Ask FixBot
    1. Astro A50 2016  Headset Battery Replacement, Headset Battery: step 5, image 1 of 2 Astro A50 2016  Headset Battery Replacement, Headset Battery: step 5, image 2 of 2
      • Remove the five 6mm PH1 screws.
      • Remove the buttons panel by pulling the panel away from the white ribbon cord.
      Ask FixBot
    2. Astro A50 2016  Headset Battery Replacement: step 6, image 1 of 2 Astro A50 2016  Headset Battery Replacement: step 6, image 2 of 2
      • Remove the four 6mm PH1 screws.
      • Remove the tape holding the wires connected to the motherboard.
      Ask FixBot
    3. Astro A50 2016  Headset Battery Replacement: step 7, image 1 of 1
      • Remove the back panel by squeezing the two tabs together and pushing out.
      Ask FixBot
    4. Astro A50 2016  Headset Battery Replacement: step 8, image 1 of 1
      Ask FixBot
    5. Astro A50 2016  Headset Battery Replacement: step 9, image 1 of 1
      • Remove the battery by using the plastic opening tool to pry it away from the headset.
      Ask FixBot
14 other people completed this guide.
Author
with
Andrew Monson
505 Reputation
1 Guide authored
Cal Poly, Team S15-G1, Livingston Fall 2017 Member of Cal Poly, Team S15-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G1
3 Members
60 Guides authored
15 Guide Comments
Is this for the Gen III Astro a50?
vic.bianco - Reply Share
Yes it’s for the Gen 3 A50
Crisdavid - Reply Share
Where do I buy a battery though….
Brandon Phillips - Reply Share
how can I connect the new battery ?
Ahmed f - Reply Share
Past 24 Hours: 9
Past 7 Days: 69
Past 30 Days: 322
All Time: 33,285
