Astro A50 (2019) Battery Replacement
    1. Astro A50 (2019) Battery Replacement, Battery: step 1, image 1 of 2 Astro A50 (2019) Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the right side ear cushion by pulling toward you on the top tab.
      Ask FixBot
    2. Astro A50 (2019) Battery Replacement: step 2, image 1 of 3 Astro A50 (2019) Battery Replacement: step 2, image 2 of 3 Astro A50 (2019) Battery Replacement: step 2, image 3 of 3
      • Remove the speaker filter by using a prying tool and peeling it off.
      • Work your way around the filter until it comes off.
      Ask FixBot
    3. Astro A50 (2019) Battery Replacement: step 3, image 1 of 3 Astro A50 (2019) Battery Replacement: step 3, image 2 of 3 Astro A50 (2019) Battery Replacement: step 3, image 3 of 3
      • Remove all four 1.5 mm screws using the Phillips #00 screwdriver.
      • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
      Ask FixBot
    4. Astro A50 (2019) Battery Replacement: step 4, image 1 of 3 Astro A50 (2019) Battery Replacement: step 4, image 2 of 3 Astro A50 (2019) Battery Replacement: step 4, image 3 of 3
      • Remove all four 1.5 mm screws holding the motherboard using the Phillips #00 screwdriver.
      • Unplug the battery by pulling the plug.
      Ask FixBot
    5. Astro A50 (2019) Battery Replacement: step 5, image 1 of 2 Astro A50 (2019) Battery Replacement: step 5, image 2 of 2
      • Remove the old battery with a plastic opening tool.
      • Be careful to not puncture the battery or fold it.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
5 other people completed this guide.
CSU Los Angeles, Team 11-6, Grodsky Fall 2021 Member of CSU Los Angeles, Team 11-6, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G6
2 Members
12 Guides authored
8 Guide Comments
Where did you source the battery for this? Do you have the part number at least? Astro doesn't sell them.
Thomas Garcia - Reply Share
I am also looking for this without having to get them from china as it will take 4 to 6 weeks to get it. Any local source for this battery?
billy7183 - Reply Share
I had to order from China, only batteries that are held domestically I could find were for the gen3/solder only and not the connector style
Luft - Reply Share
For those with a gen3 a50, the battery is mounted slightly different, you don't need to remove the PCB, just pinch the black tabs holding the outer cover on. See here: https://imgur.com/a/m2Nv2Ze
Wouter V - Reply Share
I performed this battery replacement. I sourced a new battery from another new A50 Gen 4 that was firmware bricked.
I’m having an issue charging the new battery with the base station. The headset does not seem to accept a charge from the base station however it will charge via a micro USB cable plugged into a usb wall brick.
I believe the issue is related to the battery not being calibrated to the old headset. Any ideas?
William Patterson - Reply Share
Past 24 Hours: 10
Past 7 Days: 79
Past 30 Days: 382
All Time: 24,198
