Astro A40 TR Plus Mixamp M80 Headband Replacement
    1. Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: step 1, image 1 of 3 Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: step 1, image 2 of 3 Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: step 1, image 3 of 3
      • Use a screwdriver with a H2.0 head to remove the two screws on the upper headband plate.
      • Use a screwdriver with a T9 bit to remove one screw from the upper headband plate.
      • Remove the upper headband plate.
      • Repeat the past three steps for the upper headband plate on the other side.
      Ask FixBot
    2. Astro A40 TR Plus Mixamp M80 Headband Replacement: step 2, image 1 of 3 Astro A40 TR Plus Mixamp M80 Headband Replacement: step 2, image 2 of 3 Astro A40 TR Plus Mixamp M80 Headband Replacement: step 2, image 3 of 3
      • Use a screwdriver with a H2.0 head to remove the two screws on the lower headband plate.
      • Use a screwdriver with a T9 bit to remove one screw from the lower headband plate.
      • Remove the lower headband plate.
      • Repeat the past three steps for the lower headband plate on the other side.
      Ask FixBot
    3. Astro A40 TR Plus Mixamp M80 Headband Replacement: step 3, image 1 of 1
      • Use your hand to remove the headband adjuster.
      Ask FixBot
1 Guide Comment
What screws are used for the orange circle screws you took out? I’m looking for replacements for mine and can’t seem to find them online anywhere.
Benito Pak - Reply Share
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 106
All Time: 3,927
