Up to 20% off select tools
Astro A40 Gen2 Mixamp Motherboard Replacement
Views: 9.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
104
All Time:
9,421
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In this guide, we will be reaching and removing the motherboard from its housing in the Astro A40 Gen2. The motherboard is the only component inside the mixamp.
WARNING: Use caution when placing screws to the side as they are very small and easy to lose. Place them in groups apart from each other to avoid confusion.
    1. Astro A40 Gen2 Mixamp Motherboard Replacement, Remove Dials: step 1, image 1 of 3 Astro A40 Gen2 Mixamp Motherboard Replacement, Remove Dials: step 1, image 2 of 3 Astro A40 Gen2 Mixamp Motherboard Replacement, Remove Dials: step 1, image 3 of 3
      • Remove the dials using either a metal spudger or your hands. Be careful as the dials may be difficult to remove.
      Ask FixBot
    1. Astro A40 Gen2 Mixamp Motherboard Replacement, Remove nuts and washers.: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Locate the two 11/32 inch nuts underneath the dials.
      • Use an 11/32 inch socket wrench or tweezers to unscrew and remove the nuts and washers.
      Ask FixBot
    2. Astro A40 Gen2 Mixamp Motherboard Replacement, Remove back pad.: step 3, image 1 of 2 Astro A40 Gen2 Mixamp Motherboard Replacement, Remove back pad.: step 3, image 2 of 2
      • Using a larger metal spudger, remove the rubber back of the mixamp.
      • The back will have glue residue after removal. Depending on the stickiness of the residue, more glue may be needed to stick the backing back on.
      Ask FixBot
    3. Astro A40 Gen2 Mixamp Motherboard Replacement, Take out main case screw.: step 4, image 1 of 1
      • Remove the one 4.5 mm Phillips #0 screw on the back panel of the mixamp.
      Ask FixBot
    4. Astro A40 Gen2 Mixamp Motherboard Replacement, Pry open the case.: step 5, image 1 of 3 Astro A40 Gen2 Mixamp Motherboard Replacement, Pry open the case.: step 5, image 2 of 3 Astro A40 Gen2 Mixamp Motherboard Replacement, Pry open the case.: step 5, image 3 of 3
      • Using a large metal spudger, detach all plastic clips holding the bottom and top casings together.
      • Remove the input casing using your fingers.
      • Be careful when releasing the clips between the two casings, as it is very easy to scratch the mixamp or break the clips.
      • Use caution when pulling the two casings apart as it is very easy to pinch your fingers between them.
      Ask FixBot
    5. Astro A40 Gen2 Mixamp Motherboard Replacement, Remove the motherboard from the case.: step 6, image 1 of 1
      • Remove the four 5.8 mm Phillips #0 screws on the motherboard.
      Ask FixBot
    6. Astro A40 Gen2 Mixamp Motherboard Replacement: step 7, image 1 of 2 Astro A40 Gen2 Mixamp Motherboard Replacement: step 7, image 2 of 2
      • Remove the motherboard from the casing.
      Ask FixBot
2 other people completed this guide.
Author
with
Mark
412 Reputation
3 Guides authored
Cal Poly, Team 20-18, Maness Winter 2015 Member of Cal Poly, Team 20-18, Maness Winter 2015
CPSU-MANESS-W15S20G18
4 Members
60 Guides authored
1 Guide Comment
Where would I find a motherboard? And would it save money fixing the mixamp?
benaiah paul - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 104
All Time: 9,421
