Up to 20% off select tools
Astro A20 Microphone Replacement
Views: 16K
View statistics:
Past 24 Hours:
9
Past 7 Days:
43
Past 30 Days:
169
All Time:
16,307
Comments: 9
4 comments on steps, 5 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
  • Spudger
    4.9
  • Phillips #1 Screwdriver
    5
Introduction
Go to step 1 ↓
The Astro A20 microphone replacement guide shows the steps of replacing a microphone with the use of a 60 mm extension, Phillips #1 screwdriver, and a new microphone.
    1. Astro A20  Microphone Replacement, Cushion: step 1, image 1 of 1
      • Place one hand on the hard side of the headset ear portion and on the cushion.
      • Lift the small portion on the edge of the cushion.
      Ask FixBot
    2. Astro A20  Microphone Replacement: step 2, image 1 of 1
      • Slide the metal spudger underneath the lift part of the ear cushion.
      • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
      Ask FixBot
    3. Astro A20  Microphone Replacement: step 3, image 1 of 2 Astro A20  Microphone Replacement: step 3, image 2 of 2
      • Remove the ear cushion from the headset.
      Ask FixBot
    1. Astro A20  Microphone Replacement, Microphone: step 4, image 1 of 1
      • Place one hand on the back of the speaker.
      Ask FixBot
    2. Astro A20  Microphone Replacement: step 5, image 1 of 2 Astro A20  Microphone Replacement: step 5, image 2 of 2
      • Remove the four 7mm screws with a Phillips #1 screwdriver.
      • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
      Ask FixBot
    3. Astro A20  Microphone Replacement: step 6, image 1 of 2 Astro A20  Microphone Replacement: step 6, image 2 of 2
      • Lift the speaker area.
      • Disconnect the wires that connect the microphone.
      • Remove the 7mm screw with a Phillips #1 screwdriver.
      Ask FixBot
9 other people completed this guide.
Author
with
Jasmine Yarbrough
1,017 Reputation
5 Guides authored
5 Guide Comments
worked for me….thanks
Thompson Crusher - Reply Share
listen my mic peace is messed up is there like a fix for that
Bruh Bruh - Reply Share
were? are you getting the new mic from? please link the site
jrod6t9 - Reply Share
this really worked! There was no need to get a replacement mic since it was just a torn cable not making good contact. Thanks a lot!
Lineth Jauregui - Reply Share
Past 24 Hours: 9
Past 7 Days: 43
Past 30 Days: 169
All Time: 16,307
