Astro A10 Gen2 Tighten Microphone
View statistics:
Past 24 Hours:
8
Past 7 Days:
30
Past 30 Days:
98
All Time:
328
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 35 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Prerequisite guide not required nor the exact model but it was helpful inspiration for mine.
Parts
Tools
    1. Astro A10 Gen2 Tighten Microphone, Cushion: step 1, image 1 of 1
      • Place one hand on the hard side of the headset ear portion and on the cushion.
      • Lift the small portion on the edge of the cushion.
      Ask FixBot
    2. Astro A10 Gen2 Tighten Microphone: step 2, image 1 of 1
      • Slide the metal spudger underneath the lift part of the ear cushion.
      • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
      Ask FixBot
    3. Astro A10 Gen2 Tighten Microphone: step 3, image 1 of 2 Astro A10 Gen2 Tighten Microphone: step 3, image 2 of 2
      • Remove the ear cushion from the headset.
      Ask FixBot
    1. Astro A10 Gen2 Tighten Microphone, Microphone: step 4, image 1 of 1
      • Place one hand on the back of the speaker.
      Ask FixBot
    2. Astro A10 Gen2 Tighten Microphone: step 5, image 1 of 2 Astro A10 Gen2 Tighten Microphone: step 5, image 2 of 2
      • Remove the four 7mm screws with a Phillips #1 screwdriver.
      • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
      Ask FixBot
    3. Astro A10 Gen2 Tighten Microphone: step 6, image 1 of 2 Astro A10 Gen2 Tighten Microphone: step 6, image 2 of 2
      • Lift the speaker area.
      • Disconnect the wires that connect the microphone.
      • Remove the 7mm screw with a Phillips #1 screwdriver.
      Ask FixBot
    1. Astro A10 Gen2 Tighten Microphone, Lift Ear Cushion: step 7, image 1 of 2 Astro A10 Gen2 Tighten Microphone, Lift Ear Cushion: step 7, image 2 of 2
      • Gently lift the ear cup around the edges of the headphone, starting with one point and making your way around until all the clear edges of the cushion are pulled out.
      • If you're having difficulty (taking it off or putting it back together), try pinching around the seams of the fabric and the plastic rubber.
      Ask FixBot
    2. Astro A10 Gen2 Tighten Microphone, Open Housing: step 8, image 1 of 2 Astro A10 Gen2 Tighten Microphone, Open Housing: step 8, image 2 of 2
      • Using the Torx screwdriver, remove the 4 screws holding the housing together.
      Ask FixBot
    3. Astro A10 Gen2 Tighten Microphone, Unscrew Plastic Frame: step 9, image 1 of 2 Astro A10 Gen2 Tighten Microphone, Unscrew Plastic Frame: step 9, image 2 of 2
      • Using the Phillips screwdriver, unscrew the 4 screws holding the plastic piece and the frame together.
      Ask FixBot
    4. Astro A10 Gen2 Tighten Microphone, Disconnect Battery Wire: step 10, image 1 of 1
      • Using a plastic pry tool, disconnect the battery (it may take some wiggling from each side).
      • Be careful with hitting any other wires or pieces.
      Ask FixBot
    5. Astro A10 Gen2 Tighten Microphone, Plastic Frame Pieces: step 11, image 1 of 3 Astro A10 Gen2 Tighten Microphone, Plastic Frame Pieces: step 11, image 2 of 3 Astro A10 Gen2 Tighten Microphone, Plastic Frame Pieces: step 11, image 3 of 3
      • Take care to not lose the plastic pieces the screws were attached to, as well as take note of the direction they were facing.
      • Lift the frame away from the headphone housing.
      Ask FixBot
    6. Astro A10 Gen2 Tighten Microphone, Aux Port: step 12, image 1 of 3 Astro A10 Gen2 Tighten Microphone, Aux Port: step 12, image 2 of 3 Astro A10 Gen2 Tighten Microphone, Aux Port: step 12, image 3 of 3
      • Unscrew the 2 Phillips screws holding the aux port.
      • Gently wiggle the port out of the enclosure. If you're having difficulty, try using the spudger to lift it out.
      Ask FixBot
    7. Astro A10 Gen2 Tighten Microphone, Tighten Microphone: step 13, image 1 of 2 Astro A10 Gen2 Tighten Microphone, Tighten Microphone: step 13, image 2 of 2
      • Ensure the microphone is flush against the outside of the housing. Make sure to pull through any excess wire so it isn't caught.
      • Screw the microphone back in using the Phillips screw. EDIT: Before fully tightening the screw, I found it was more secure if you extended the microphone (like when you have it by your mouth to speak) and tightening the screw while it was in that position.
      • My wires were still intact and I still had the screw, so that's all I needed to do. To put everything back together, just go in reverse.
      Ask FixBot
EDIT: I found that unscrewing the plastic frame FIRST was easier to have room to disconnect the battery, so I updated the guide as such.
C.J. Tran
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 30
Past 30 Days: 98
All Time: 328
