Up to 20% off select tools
Astak Mole Camera Head Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
92
All Time:
1,198
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
  • Spudger
    4.9
  • Phillips #1 Screwdriver
    5
Introduction
Go to step 1 ↓
In order for you to replace the camera head, you will have to separate the base and the camera head by disconnecting some wires that lead from the head to the motherboard.
    1. Astak Mole Camera Head Replacement, Lower Case: step 1, image 1 of 1
      • Remove the four bottom tabs in order to access the bottom screws.
      Ask FixBot
    2. Astak Mole Camera Head Replacement: step 2, image 1 of 1
      • Remove all four 14 mm Phillips #1 screws.
      Ask FixBot
    3. Astak Mole Camera Head Replacement: step 3, image 1 of 1
      • Remove the SD card.
      Ask FixBot
    4. Astak Mole Camera Head Replacement: step 4, image 1 of 1
      • Pry up the motherboard on the four points using a spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      Ask FixBot
    5. Astak Mole Camera Head Replacement: step 5, image 1 of 1
      • Gently pull back the motherboard to expose many of the component's wired connections.
      Ask FixBot
    1. Astak Mole Camera Head Replacement, Camera Head: step 6, image 1 of 1
      • Unscrew the three screws connecting the base to the camera head with the PH1 size Phillips head bit.
      • Screw measurements: Length=7.0mm.
      • The third screw can be exposed by rotating the camera head.
      • Do not force the camera head farther than it will allow you.
      Ask FixBot
    2. Astak Mole Camera Head Replacement: step 7, image 1 of 1
      • Unscrew indicated Phillips head screws using the PH1 Phillips head bit to free wires.
      • Screw measurements: Length=3.5mm
      Ask FixBot
    3. Astak Mole Camera Head Replacement: step 8, image 1 of 3 Astak Mole Camera Head Replacement: step 8, image 2 of 3 Astak Mole Camera Head Replacement: step 8, image 3 of 3
      • Separate the three indicated outputs from the motherboard with metal spudger.
      • There is electrical adhesive on the output. This can be easily separated with the metal spudger.
      Ask FixBot
    4. Astak Mole Camera Head Replacement: step 9, image 1 of 1
      • Separate the wire from CPU by cutting adhesive with metal spudger.
      • It is advised to reapply adhesive to wired connections during reassembly, and to re-attach wires to CPU to prevent disconnection and loose wires inside device.
      • Be careful not to damage the CPU in the process. This is not a wired connection.
      Ask FixBot
Author
with
Bryan
104 Reputation
1 Guide authored
USF Tampa, Team 2-2, Blackwell Fall 2016 Member of USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 92
All Time: 1,198
