Astak Mole Antenna Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
79
All Time:
1,144
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
If you getting a new antenna doesn't work, there might be a problem with the antenna connection inside the camera. This guide will show you how to replace input cable that attaches the antenna to the motherboard.
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Astak Mole Antenna Replacement, Lower Case: step 1, image 1 of 1
      • Remove the four bottom tabs in order to access the bottom screws.
      Ask FixBot
    2. Astak Mole Antenna Replacement: step 2, image 1 of 1
      • Remove all four 14 mm Phillips #1 screws.
      Ask FixBot
    3. Astak Mole Antenna Replacement: step 3, image 1 of 1
      • Remove the SD card.
      Ask FixBot
    4. Astak Mole Antenna Replacement: step 4, image 1 of 1
      • Pry up the motherboard on the four points using a spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      Ask FixBot
    5. Astak Mole Antenna Replacement: step 5, image 1 of 1
      • Gently pull back the motherboard to expose many of the component's wired connections.
      Ask FixBot
    1. Astak Mole Antenna Replacement, Antenna: step 6, image 1 of 2 Astak Mole Antenna Replacement, Antenna: step 6, image 2 of 2
      • Unscrew the antenna in a counter-clockwise rotation.
      Ask FixBot
    2. Astak Mole Antenna Replacement: step 7, image 1 of 1
      • Take out the screw holding the antenna wire with the PH1 size Phillips head bit.
      • Screw length: 5.3mm
      Ask FixBot
    3. Astak Mole Antenna Replacement: step 8, image 1 of 1
      • Gently pry open the circuit board attached to the antenna wire using a metal spudger.
      Ask FixBot
    4. Astak Mole Antenna Replacement: step 9, image 1 of 1
      • Remove the antenna female end from the motherboard.
      Ask FixBot
Meshari Alkhelaiwi
155 Reputation
1 Guide authored
USF Tampa, Team 2-2, Blackwell Fall 2016 Member of USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 79
All Time: 1,144
