Up to 20% off select tools
Astak Mole Motor Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
100
All Time:
1,080
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
  • Spudger
    4.9
  • Phillips #1 Screwdriver
    5
Introduction
Go to step 1 ↓
Replacing the motor requires access to the motherboard and it is suggested to place screws into magnetic tray to avoid loss of important screws. Removal of the rotational motor assembly is simple but it may be difficult to find a replacement motor online.
    1. Astak Mole  Motor Replacement, Lower Case: step 1, image 1 of 1
      • Remove the four bottom tabs in order to access the bottom screws.
      Ask FixBot
    2. Astak Mole  Motor Replacement: step 2, image 1 of 1
      • Remove all four 14 mm Phillips #1 screws.
      Ask FixBot
    3. Astak Mole  Motor Replacement: step 3, image 1 of 1
      • Remove the SD card.
      Ask FixBot
    4. Astak Mole  Motor Replacement: step 4, image 1 of 1
      • Pry up the motherboard on the four points using a spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      Ask FixBot
    5. Astak Mole  Motor Replacement: step 5, image 1 of 1
      • Gently pull back the motherboard to expose many of the component's wired connections.
      Ask FixBot
    1. Astak Mole  Motor Replacement, Electric Motor Assembly: step 6, image 1 of 1
      • Unscrew both screws using the Phillips head (PH1) screw bit and set aside for reassembly
      • Screw Measurements: Length: 7.1mm
      • The motor should be free of its housing and only be attached to the motherboard by its wires.
      Ask FixBot
    2. Astak Mole  Motor Replacement: step 7, image 1 of 1
      • Sever motor connection to motherboard and remove wire carefully.
      • Optional: Use electrical adhesive to prevent dislodging of new wired connection.
      Ask FixBot
Author
with
Andrew Birch
204 Reputation
2 Guides authored
USF Tampa, Team 2-2, Blackwell Fall 2016 Member of USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 100
All Time: 1,080
