This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Assembly of aerial socket outlet, European model.
  1. Assembly of aerial socket outlet, European model., SOCKET ASSEMBLY: step 1, image 1 of 3 Assembly of aerial socket outlet, European model., SOCKET ASSEMBLY: step 1, image 2 of 3 Assembly of aerial socket outlet, European model., SOCKET ASSEMBLY: step 1, image 3 of 3
    • Assembly of an aerial plug socket (European) on a 1.5 m cable, removing the PC screen power socket (Recycling a cable for another use).
    Ask FixBot
  2. Assembly of aerial socket outlet, European model.: step 2, image 1 of 1
    • Disassembly of the aerial intake screw.
    Ask FixBot
  3. Assembly of aerial socket outlet, European model.: step 3, image 1 of 3 Assembly of aerial socket outlet, European model.: step 3, image 2 of 3 Assembly of aerial socket outlet, European model.: step 3, image 3 of 3
    • Identification of the terminals, we will connect Phase and Neutral at the 2 ends, ground at the central screw.
    Ask FixBot
  4. Assembly of aerial socket outlet, European model.: step 4, image 1 of 1
    • Unscrewed from the screws to open the connection point.
    Ask FixBot
  5. Assembly of aerial socket outlet, European model.: step 5, image 1 of 2 Assembly of aerial socket outlet, European model.: step 5, image 2 of 2
    • To cut the wire flush with the connector to be removed, we can use electrician's scissors, electrician's wire cutters, fine electronics wire cutters.
    Ask FixBot
  6. Assembly of aerial socket outlet, European model.: step 6, image 1 of 2 Assembly of aerial socket outlet, European model.: step 6, image 2 of 2
    • Cut flush, to take advantage of the full length of the cable
    Ask FixBot
  7. Assembly of aerial socket outlet, European model.: step 7, image 1 of 3 Assembly of aerial socket outlet, European model.: step 7, image 2 of 3 Assembly of aerial socket outlet, European model.: step 7, image 3 of 3
    • VERY IMPORTANT STEP, to avoid forgetting to insert the cover, (It has happened to all of us, not once, but more than once, it will be the first thing we insert).
    • We take the measurement of the piece of white hose to peel or strip, more or less about 2 cm, note that from one manufacturer of bases on plugs to another this measurement can vary.
    Ask FixBot
  8. Assembly of aerial socket outlet, European model.: step 8, image 1 of 3 Assembly of aerial socket outlet, European model.: step 8, image 2 of 3 Assembly of aerial socket outlet, European model.: step 8, image 3 of 3
    • With the scissors, CAREFULLY APPLYING ONLY LIGHT PRESSURE and turning in a circle, we will mark the stopping point to which it must be drawn.
    • To peel the cover carefully, we can do it with scissors.
    Ask FixBot
  9. Assembly of aerial socket outlet, European model.: step 9, image 1 of 3 Assembly of aerial socket outlet, European model.: step 9, image 2 of 3 Assembly of aerial socket outlet, European model.: step 9, image 3 of 3
    • Another peeling option is to make a slight cut with a utility knife and use fine electronic cutting pliers to help us.
    Ask FixBot
  10. Assembly of aerial socket outlet, European model.: step 10, image 1 of 3 Assembly of aerial socket outlet, European model.: step 10, image 2 of 3 Assembly of aerial socket outlet, European model.: step 10, image 3 of 3
    • We remove the white rubber cover, separate the wires, and without excessive pressure with the scissors, just marking the plastic, we proceed to strip it.
    • I like to rest the scissors on my thumb, as a fulcrum to be able to lever.
    Ask FixBot
  11. Assembly of aerial socket outlet, European model.: step 11, image 1 of 2 Assembly of aerial socket outlet, European model.: step 11, image 2 of 2
    • Inserted the cables into the connections and tightened the fixing screws.
    Ask FixBot
  12. Assembly of aerial socket outlet, European model.: step 12, image 1 of 3 Assembly of aerial socket outlet, European model.: step 12, image 2 of 3 Assembly of aerial socket outlet, European model.: step 12, image 3 of 3
    • Tight and fastening.
    Ask FixBot
  13. Assembly of aerial socket outlet, European model.: step 13, image 1 of 3 Assembly of aerial socket outlet, European model.: step 13, image 2 of 3 Assembly of aerial socket outlet, European model.: step 13, image 3 of 3
    • Personally, I like to apply a drop of petroleum jelly to screws that are inserted into plastic.
    • 1st It greatly facilitates the smooth insertion of the screw.
    • 2nd Avoid or minimize the plastic cracking or breaking, facilitating future disassembly of the plug socket.
    Ask FixBot
  14. Assembly of aerial socket outlet, European model.: step 14, image 1 of 2 Assembly of aerial socket outlet, European model.: step 14, image 2 of 2
    • "View of the assembled (one)."
    Ask FixBot
  15. Assembly of aerial socket outlet, European model.: step 15, image 1 of 2 Assembly of aerial socket outlet, European model.: step 15, image 2 of 2
    • Application of another drop of petroleum jelly where the closing screw will be inserted.
    Ask FixBot
  16. Assembly of aerial socket outlet, European model.: step 16, image 1 of 3 Assembly of aerial socket outlet, European model.: step 16, image 2 of 3 Assembly of aerial socket outlet, European model.: step 16, image 3 of 3
    • When the cover is on, the cover and the base have a specific mounting position; if it's upside down, it cannot be screwed in, and many cannot even be assembled.
    Ask FixBot
  17. Assembly of aerial socket outlet, European model.: step 17, image 1 of 3 Assembly of aerial socket outlet, European model.: step 17, image 2 of 3 Assembly of aerial socket outlet, European model.: step 17, image 3 of 3
    • Screw insert.
    • I hope this step-by-step guide is useful to you, as all aerial views of the socket are very similar.
    Ask FixBot
Finish Line
4 other people completed this guide.
Special thanks to these translators:
es en
94%
redratchet21 is helping us fix the world! Want to contribute?
Start translating ›
Carlos López (España - Spain)
100,437 Reputation
362 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 61
Past 30 Days: 254
All Time: 2,200
