Assembling the case
Views: 1.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
80
All Time:
1,715
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Assembling the case
Introduction
Go to step 1 ↓
These instructions will help you to close the machine housing of your Jura Impressa F50 coffee machine again.
      • Reinstall the left side panel.
      • Put on the side wall and make sure that the lugs are snapped into the slots provided. Then slide the side panel slightly forward. The side panel should audibly snap into place when pushed forward.
      Ask FixBot
      • Reinstall the right side panel.
      • First attach the side wall and make sure that the lugs have snapped into the slots provided. Then slide the side panel slightly forward. The side panel should audibly snap into place when pushed forward.
      Ask FixBot
    1. Assembling the case: step 3, image 1 of 1
      • Place the housing cover back on the coffee maker.
      Ask FixBot
    2. Assembling the case: step 4, image 1 of 2 Assembling the case: step 4, image 2 of 2
      • Use the Torx T15 screwdriver to tighten the 2 countersunk screws on the housing cover.
      Ask FixBot
    3. Assembling the case: step 5, image 1 of 2 Assembling the case: step 5, image 2 of 2
      • Using the oval head wrench, tighten the 4 oval head screws on the back of the machine.
      Ask FixBot
    4. Assembling the case: step 6, image 1 of 3 Assembling the case: step 6, image 2 of 3 Assembling the case: step 6, image 3 of 3
      • Replace the water tank,
      • the drip tray with drip tray, pulp tray and pulp container,
      • and place the aroma protection cover back on.
      Ask FixBot
Finish Line
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Natalie
759 Reputation
4 Guides authored
KMM 2019SS Member of KMM 2019SS
Community
11 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 80
All Time: 1,715
