Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar
    1. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Tripod Base Stand: step 1, image 1 of 2 Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Tripod Base Stand: step 1, image 2 of 2
      • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
      • Be sure the flat side of each tripod leg is facing toward the ground.
      Ask FixBot
    2. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: step 2, image 1 of 1
      • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
      Ask FixBot
    1. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: step 3, image 1 of 2 Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: step 3, image 2 of 2
      • Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly.
      • It does not matter which direction the 14mm bolt is inserted from.
      Ask FixBot
To disassemble your device, follow these instructions in reverse order.
2 other people completed this guide.
Ashlie Reott
340 Reputation
3 Guides authored
Cal Poly, Team 4-30, Amido Fall 2013 Member of Cal Poly, Team 4-30, Amido Fall 2013
CPSU-AMIDO-F13S4G30
4 Members
72 Guides authored
1 Guide Comment
Can I order the following part that was missing from the order that came in Aug 2025?
Please let me know, I can pay for these parts from you stock or spare parts.
36 x 10mm Nut/Bolt Pairs
6 Pipe Ring Brackets
12 x 14mm Nut/Bolt Pairs
2 Cooker Assembly Adjustment Star Knobs
Paul
my email is pn91006@yahoo.com
626-215-4038
Paul Ng
Paul Paul - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 47
All Time: 1,037
