Up to 20% off select tools
ArmorAll AA255 Switch Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
111
All Time:
3,935
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Make sure the cord is unplugged.
    1. ArmorAll AA255 Switch Replacement, Lower Motor Housing: step 1, image 1 of 1
      • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
      Ask FixBot
    2. ArmorAll AA255 Switch Replacement: step 2, image 1 of 1
      • Remove the five 15mm PH2 screws.
      Ask FixBot
    3. ArmorAll AA255 Switch Replacement: step 3, image 1 of 1
      • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
      Ask FixBot
    4. ArmorAll AA255 Switch Replacement: step 4, image 1 of 2 ArmorAll AA255 Switch Replacement: step 4, image 2 of 2
      • Gently separate the upper and lower sections of the main housing.
      Ask FixBot
    1. ArmorAll AA255 Switch Replacement, Switch: step 5, image 1 of 1
      • Using a PH2 screw head, unscrew the two 15mm screws as shown.
      Ask FixBot
    2. ArmorAll AA255 Switch Replacement: step 6, image 1 of 3 ArmorAll AA255 Switch Replacement: step 6, image 2 of 3 ArmorAll AA255 Switch Replacement: step 6, image 3 of 3
      • Pull the black handle.
      • Using a PH2 screwdriver, unscrew the single 12mm screw shown.
      Ask FixBot
    3. ArmorAll AA255 Switch Replacement: step 7, image 1 of 2 ArmorAll AA255 Switch Replacement: step 7, image 2 of 2
      • Use the blue opening tool to open up the black handle.
      Ask FixBot
    4. ArmorAll AA255 Switch Replacement: step 8, image 1 of 2 ArmorAll AA255 Switch Replacement: step 8, image 2 of 2
      • Using your fingers, gently take out the black cords.
      • Careful to not break the black cords.
      Ask FixBot
    5. ArmorAll AA255 Switch Replacement: step 9, image 1 of 2 ArmorAll AA255 Switch Replacement: step 9, image 2 of 2
      • Using the spudger, take out the switch. Do this by pushing the spudger against the switch on both sides as shown and then pull the switch out.
      Ask FixBot
    6. ArmorAll AA255 Switch Replacement: step 10, image 1 of 1
      • Replace the switch shown.
      Ask FixBot
2 other people completed this guide.
Author
with
Renzo La Rosa
224 Reputation
1 Guide authored
IUPUI, Team 2-1, Baechle Spring 2016 Member of IUPUI, Team 2-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G1
4 Members
48 Guides authored
1 Guide Comment
Any idea where to find a replacement switch? I did not see one on Amazon or eBay.
Mitchell Taylor - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 111
All Time: 3,935
