ArmorAll AA255 Power Cord Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
106
All Time:
1,760
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
Unplug the vacuum before repair. The cord is easily disconnected and replaced once the vacuum is disassembled adequately.
Tools
    1. ArmorAll AA255 Power Cord Replacement, Lower Motor Housing: step 1, image 1 of 1
      • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
      Ask FixBot
    2. ArmorAll AA255 Power Cord Replacement: step 2, image 1 of 1
      • Remove the five 15mm PH2 screws.
      Ask FixBot
    3. ArmorAll AA255 Power Cord Replacement: step 3, image 1 of 1
      • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
      Ask FixBot
    4. ArmorAll AA255 Power Cord Replacement: step 4, image 1 of 2 ArmorAll AA255 Power Cord Replacement: step 4, image 2 of 2
      • Gently separate the upper and lower sections of the main housing.
      Ask FixBot
    1. ArmorAll AA255 Power Cord Replacement, Power Cord: step 5, image 1 of 1
      • Pull the black wire from the power cord out of the switch.
      • There are no clips or tabs that hold this wire in place. Just pull strongly to remove it.
      • Don't remove both black wires. Only the black wire that comes from the power cord itself needs to be removed. The one going to the motor can be left alone.
      Ask FixBot
    2. ArmorAll AA255 Power Cord Replacement: step 6, image 1 of 1
      • Remove the five 15mm screws from the plastic motor cover and power cord clamp using a PH2 screwdriver.
      Ask FixBot
    3. ArmorAll AA255 Power Cord Replacement: step 7, image 1 of 2 ArmorAll AA255 Power Cord Replacement: step 7, image 2 of 2
      • Remove the plastic motor cover.
      • Be sure to loosen the white wire from the notch in the plastic motor cover by pulling it upwards.
      Ask FixBot
    4. ArmorAll AA255 Power Cord Replacement: step 8, image 1 of 2 ArmorAll AA255 Power Cord Replacement: step 8, image 2 of 2
      • Detach the white wire from the motor by pulling upwards on the wire as you depress the small metal tab on the connector with a nylon spudger.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Ask FixBot
3 other people completed this guide.
Abel Manring
263 Reputation
1 Guide authored
IUPUI, Team 2-1, Baechle Spring 2016 Member of IUPUI, Team 2-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G1
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 106
All Time: 1,760
