ArmorAll AA255 Motor Replacement
Views: 6.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
31
Past 30 Days:
139
All Time:
6,095
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 35 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
The device will be disassembled down to the motor, the power cords will be disconnected, and the motor removed of your ArmorAll AA255.
Tools
    1. ArmorAll AA255 Motor Replacement, Lower Motor Housing: step 1, image 1 of 1
      • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
      Ask FixBot
    2. ArmorAll AA255 Motor Replacement: step 2, image 1 of 1
      • Remove the five 15mm PH2 screws.
      Ask FixBot
    3. ArmorAll AA255 Motor Replacement: step 3, image 1 of 1
      • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
      Ask FixBot
    4. ArmorAll AA255 Motor Replacement: step 4, image 1 of 2 ArmorAll AA255 Motor Replacement: step 4, image 2 of 2
      • Gently separate the upper and lower sections of the main housing.
      Ask FixBot
    1. ArmorAll AA255 Motor Replacement, Motor: step 5, image 1 of 3 ArmorAll AA255 Motor Replacement, Motor: step 5, image 2 of 3 ArmorAll AA255 Motor Replacement, Motor: step 5, image 3 of 3
      • Use a PH2 screwdriver to remove the five 15mm screws on the ball cage under the main housing.
      • Pull the ball cage to remove it from the main housing.
      Ask FixBot
    2. ArmorAll AA255 Motor Replacement: step 6, image 1 of 3 ArmorAll AA255 Motor Replacement: step 6, image 2 of 3 ArmorAll AA255 Motor Replacement: step 6, image 3 of 3
      • Remove one 13mm nut from the main housing.
      • The metal ring under the nut has sharp edges. You may need to use a tool such as pliers to prevent injury.
      • Remove metal ring from the main housing.
      • Use a PH2 screwdriver to remove the four 12mm screws from the main housing.
      Ask FixBot
    3. ArmorAll AA255 Motor Replacement: step 7, image 1 of 3 ArmorAll AA255 Motor Replacement: step 7, image 2 of 3 ArmorAll AA255 Motor Replacement: step 7, image 3 of 3
      • Turn the whole body over to separate motor cover.
      • Use a PH2 screwdriver to remove the five 15mm screw.
      • Remove the white power wire from the motor cover.
      • Pull the motor cover from the main housing.
      Ask FixBot
    4. ArmorAll AA255 Motor Replacement: step 8, image 1 of 2 ArmorAll AA255 Motor Replacement: step 8, image 2 of 2
      • Use a plastic opening tool to remove two cables from the motor. One white cable is from the power cord, and one black cable is from the switch.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      • You may need to mark the color of the wire on each terminal for reassembly.
      Ask FixBot
    5. ArmorAll AA255 Motor Replacement: step 9, image 1 of 2 ArmorAll AA255 Motor Replacement: step 9, image 2 of 2
      • The motor is ready for replacement. Pull the motor to separate.
      Ask FixBot
6 other people completed this guide.
YeaJun Yoo
302 Reputation
1 Guide authored
IUPUI, Team 2-1, Baechle Spring 2016 Member of IUPUI, Team 2-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G1
4 Members
48 Guides authored
4 Guide Comments
What is the motor product no? It will help if there is a link to buy the motor
Austin K - Reply Share
Medida de los carboncitos que lleva el motor?
SERVANDO ARTEA FAVELA - Reply Share
Buenas nochew necesito saber si existe a la venta la hélice o ventiladora que hace la succión de la aspiradora. Porfavor alguien puede ayudarme dejo mi correo erikazavala2882@gmail.com desde Honduras.
erikazavala2882 - Reply Share
Part #for motor ???? Mine just the carbon brush is worn. Need replacement part # for motor or brushes ????
A Anderson - Reply Share
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 139
All Time: 6,095
