Arlo Ultra 2 Motion Sensor Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
71
All Time:
876
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
The motion sensor component signals to start recording when motion is detected in your Arlo Ultra 2 home security camera. If the motion sensor in your Arlo Ultra 2 is malfunctioning then follow this guide to replace the motion sensor.
When the motion sensor begins to malfunction, refer to the troubleshooting page prior to beginning this repair to see if there is an alternative fix.
Before beginning this guide it's important to disconnect your camera from the charger or a wired set up.
Tools
    1. Arlo Ultra 2 Motion Sensor Replacement, Battery: step 1, image 1 of 2 Arlo Ultra 2 Motion Sensor Replacement, Battery: step 1, image 2 of 2
      • Press the button on the bottom of the camera to release the housing.
      • Pull the white housing off the camera.
      Ask FixBot
    2. Arlo Ultra 2 Motion Sensor Replacement: step 2, image 1 of 1
      • Pull the white cube shaped battery from the back to remove it from camera.
      Ask FixBot
    1. Arlo Ultra 2 Motion Sensor Replacement, Speaker: step 3, image 1 of 2 Arlo Ultra 2 Motion Sensor Replacement, Speaker: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity. They are found in each corner.
      Ask FixBot
    2. Arlo Ultra 2 Motion Sensor Replacement: step 4, image 1 of 2 Arlo Ultra 2 Motion Sensor Replacement: step 4, image 2 of 2
      • Using the spudger, loosen and remove the camera faceplate.
      Ask FixBot
    3. Arlo Ultra 2 Motion Sensor Replacement: step 5, image 1 of 2 Arlo Ultra 2 Motion Sensor Replacement: step 5, image 2 of 2
      • Using the spudger, loosen and remove the back casing to expose the camera hardware.
      Ask FixBot
    4. Arlo Ultra 2 Motion Sensor Replacement: step 6, image 1 of 2 Arlo Ultra 2 Motion Sensor Replacement: step 6, image 2 of 2
      • Very gently, pry the circuit boards apart from the white connector, removing the upper circuit board.
      Ask FixBot
    5. Arlo Ultra 2 Motion Sensor Replacement: step 7, image 1 of 2 Arlo Ultra 2 Motion Sensor Replacement: step 7, image 2 of 2
      • Use a Phillips #00 screwdriver to remove two 5.0 mm screws from the metal bracket.
      • Use a spudger to separate the long metal bracket.
      • There is an arrow etched into the bracket. It points towards the top of the camera. This is important when reassembling the camera.
      Ask FixBot
    6. Arlo Ultra 2 Motion Sensor Replacement: step 8, image 1 of 3 Arlo Ultra 2 Motion Sensor Replacement: step 8, image 2 of 3 Arlo Ultra 2 Motion Sensor Replacement: step 8, image 3 of 3
      • Use the tip of a spudger or your fingernail to flip up the small locking flap on each ZIF connector. Then, you can safely pull the cables out.
      • Be sure to pry up on the hinged flap, not the connector socket.
      Ask FixBot
    7. Arlo Ultra 2 Motion Sensor Replacement: step 9, image 1 of 2 Arlo Ultra 2 Motion Sensor Replacement: step 9, image 2 of 2
      • Use a spudger to carefully push on each side of the speaker cable connector until it's out of its socket.
      Ask FixBot
    8. Arlo Ultra 2 Motion Sensor Replacement: step 10, image 1 of 1
      • Remove the small green circuit board.
      Ask FixBot
    9. Arlo Ultra 2 Motion Sensor Replacement: step 11, image 1 of 3 Arlo Ultra 2 Motion Sensor Replacement: step 11, image 2 of 3 Arlo Ultra 2 Motion Sensor Replacement: step 11, image 3 of 3
      • Feed the speaker cable through the opening to remove the speaker.
      Ask FixBot
    1. Arlo Ultra 2 Motion Sensor Replacement, Motion Sensor: step 12, image 1 of 3 Arlo Ultra 2 Motion Sensor Replacement, Motion Sensor: step 12, image 2 of 3 Arlo Ultra 2 Motion Sensor Replacement, Motion Sensor: step 12, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the two 5.0 mm screws from the metal plate.
      • Pry the plate away from the circuit board underneath.
      Ask FixBot
    2. Arlo Ultra 2 Motion Sensor Replacement: step 13, image 1 of 3 Arlo Ultra 2 Motion Sensor Replacement: step 13, image 2 of 3 Arlo Ultra 2 Motion Sensor Replacement: step 13, image 3 of 3
      • Use a spudger to remove the circuit board with the lens attached.
      Ask FixBot
    3. Arlo Ultra 2 Motion Sensor Replacement: step 14, image 1 of 3 Arlo Ultra 2 Motion Sensor Replacement: step 14, image 2 of 3 Arlo Ultra 2 Motion Sensor Replacement: step 14, image 3 of 3
      Tool used on this step:
      Buy
      • Use blunt tweezers to pull up the heat-resistant tape.
      • Pull the heat-resistant tape through to the front of the camera.
      Ask FixBot
    4. Arlo Ultra 2 Motion Sensor Replacement: step 15, image 1 of 3 Arlo Ultra 2 Motion Sensor Replacement: step 15, image 2 of 3 Arlo Ultra 2 Motion Sensor Replacement: step 15, image 3 of 3
      • Place the tip of your spudger under the edge of the motion sensor connector, and pry the connector straight up from its socket.
      Ask FixBot
    5. Arlo Ultra 2 Motion Sensor Replacement: step 16, image 1 of 2 Arlo Ultra 2 Motion Sensor Replacement: step 16, image 2 of 2
      • Use a spudger to remove the motion sensors from the housing.
      • Finish removing the entire motion sensor and microphone electric tape.
      Ask FixBot
2 Guide Comments
I wonder if you might have any insight on why these are so failure prone? I have had this happen twice since buying these cameras a little over a year ago. This would seem to be a simple part, kind of like an led bulb, typically they just don’t fail before other parts of the device have just gotten old and broken down. I know others have been having this exact issue also.
Ash Miller - Reply Share
Hello could you provide any information on part number and where to buy replacement motion sensors?
TIA
Richard Moyden - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 71
All Time: 876
