Arlo Pro 2 Base Station Motherboard Replacement
  1. Arlo Pro 2 Base Station Motherboard Replacement, Base Station Motherboard: step 1, image 1 of 3 Arlo Pro 2 Base Station Motherboard Replacement, Base Station Motherboard: step 1, image 2 of 3 Arlo Pro 2 Base Station Motherboard Replacement, Base Station Motherboard: step 1, image 3 of 3
    • Use a TR10 Torx screwdriver to remove the two 10 mm screws on the side of the base station, above the USB ports.
    • Pull apart the top case from the bottom.
    • This may require some force as there are internal catches.
    Ask FixBot
  2. Arlo Pro 2 Base Station Motherboard Replacement: step 2, image 1 of 3 Arlo Pro 2 Base Station Motherboard Replacement: step 2, image 2 of 3 Arlo Pro 2 Base Station Motherboard Replacement: step 2, image 3 of 3
    • Use a TR10 Torx screwdriver to remove the two 10 mm screws to disconnect the motherboard from the base casing.
    • The motherboard is connected to the USB ports; when removing it be careful to gently remove the USB ports from their cavities to avoid any damage.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ben I.
493 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 261
