Archos Jukebox Recorder 20 Motherboard Replacement
    1. Archos Jukebox Recorder 20 Motherboard Replacement, Battery: step 1, image 1 of 1
      • Remove the plastic cover over the batteries on both sides of the device.
      Ask FixBot
    2. Archos Jukebox Recorder 20 Motherboard Replacement: step 2, image 1 of 1
      • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
      Ask FixBot
    1. Archos Jukebox Recorder 20 Motherboard Replacement, Button Panel: step 3, image 1 of 1
      • Using the Philips Screwdriver, remove the top 2 screws.
      • The screws are very small (2.5mm), put them somewhere you won't lose them.
      Ask FixBot
    2. Archos Jukebox Recorder 20 Motherboard Replacement: step 4, image 1 of 1
      • Using the Philips screwdriver, remove the bottom 2 screws (2.5mm).
      Ask FixBot
    3. Archos Jukebox Recorder 20 Motherboard Replacement: step 5, image 1 of 2 Archos Jukebox Recorder 20 Motherboard Replacement: step 5, image 2 of 2
      • Remove the face.
      Ask FixBot
    1. Archos Jukebox Recorder 20 Motherboard Replacement, Motherboard: step 6, image 1 of 1
      • Remove four surrounding T5 screws as shown
      Ask FixBot
    2. Archos Jukebox Recorder 20 Motherboard Replacement: step 7, image 1 of 1
      • Remove all four purple bumpers. You may have to bend the metal surround out of the way.
      Ask FixBot
    3. Archos Jukebox Recorder 20 Motherboard Replacement: step 8, image 1 of 1
      • Remove metal surround from the Jukebox. You may have to straighten out tabs that were bent during disassembly.
      Ask FixBot
    4. Archos Jukebox Recorder 20 Motherboard Replacement: step 9, image 1 of 2 Archos Jukebox Recorder 20 Motherboard Replacement: step 9, image 2 of 2
      Tool used on this step:
      Desoldering Pump
      $3.99
      Buy
      • Desolder the motherboard from the frame at the eight locations shown. You may need to use a desoldering pump.
      Ask FixBot
    5. Archos Jukebox Recorder 20 Motherboard Replacement: step 10, image 1 of 2 Archos Jukebox Recorder 20 Motherboard Replacement: step 10, image 2 of 2
      • Desolder the remaining two points on the backside of the Jukebox.
      • The Motherboard should now be free from the frame and ready for repair or replacement.
      Ask FixBot
Shaun Rifield
121 Reputation
1 Guide authored
IUPUI, Team S2-G3, Freund Spring 2018 Member of IUPUI, Team S2-G3, Freund Spring 2018
IUPUI-FREUND-S18S2G3
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 72
All Time: 965
