Archos Jukebox Recorder 20 Hard Drive Replacement
    1. Archos Jukebox Recorder 20 Hard Drive  Replacement, Battery: step 1, image 1 of 1
      • Remove the plastic cover over the batteries on both sides of the device.
      Ask FixBot
    2. Archos Jukebox Recorder 20 Hard Drive  Replacement: step 2, image 1 of 1
      • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
      Ask FixBot
    1. Archos Jukebox Recorder 20 Hard Drive  Replacement, Hard Drive: step 3, image 1 of 2 Archos Jukebox Recorder 20 Hard Drive  Replacement, Hard Drive: step 3, image 2 of 2
      • Use the T10 Torx Screwdriver to remove the 2 torx screws on each side of the device.
      • Two on each side for a total of four.
      Ask FixBot
    2. Archos Jukebox Recorder 20 Hard Drive  Replacement: step 4, image 1 of 2 Archos Jukebox Recorder 20 Hard Drive  Replacement: step 4, image 2 of 2
      • Remove the 2 screws on the top and the 2 screws on the bottom of the device using a Phillips #0 screwdriver.
      Ask FixBot
    3. Archos Jukebox Recorder 20 Hard Drive  Replacement: step 5, image 1 of 1
      • Remove the outer metal casing of the device by popping it off with a plastic opening tool.
      Ask FixBot
    4. Archos Jukebox Recorder 20 Hard Drive  Replacement: step 6, image 1 of 1
      • Remove the rubber bumpers on all four corners of the device.
      Ask FixBot
    5. Archos Jukebox Recorder 20 Hard Drive  Replacement: step 7, image 1 of 2 Archos Jukebox Recorder 20 Hard Drive  Replacement: step 7, image 2 of 2
      • Lift the hard drive out of its casing with the help of a plastic opening tool and slide it out. This will disconnect the pins connecting the drive to the rest of the device.
      Ask FixBot
2 other people completed this guide.
Aidan Patterson
354 Reputation
2 Guides authored
IUPUI, Team S1-G4, Freund Spring 2018 Member of IUPUI, Team S1-G4, Freund Spring 2018
IUPUI-FREUND-S18S1G4
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 40
All Time: 2,166
