Archos 5 Headphone Jack Repair
    1. Archos 5 Headphone Jack Repair, Headphone Jack: step 1, image 1 of 1
      • Please be sure that your device is powered off before attempting any repairs.
      • Please be aware that any further steps could possibly void the warranty of your Archos 5.
      Ask FixBot
    2. Archos 5 Headphone Jack Repair: step 2, image 1 of 2 Archos 5 Headphone Jack Repair: step 2, image 2 of 2
      • Use the plastic opening tool to take off 3 black sticky pads that cover the screws.
      • Use the screwdriver(PH000) to remove the screws located under the pads. One of the screws is located under the stand.
      • Lift the stand in order to get to the fourth screw.
      Ask FixBot
    3. Archos 5 Headphone Jack Repair: step 3, image 1 of 2 Archos 5 Headphone Jack Repair: step 3, image 2 of 2
      • Carefully pry open all 4 sides of the Archos 5 using the plastic opening tool.
      • Once all sides of the device are priced open, gently open the device.
      • Be careful not to tear the foil which connects the LCD screen to the motherboard!
      Ask FixBot
    4. Archos 5 Headphone Jack Repair: step 4, image 1 of 2 Archos 5 Headphone Jack Repair: step 4, image 2 of 2
      • Once you have opened your device, fold the screen away from the battery.
      • Unplug the touch pad from the motherboard. Do this by applying pressure on the thin black piece (attached at the bottom of the metallic foil.) Press the plastic spudger against the thin black piece and release it.
      • Use a plastic spudger instead of a metal spudger!
      Ask FixBot
    5. Archos 5 Headphone Jack Repair: step 5, image 1 of 1
      • Once you have unplugged your screen, locate the headphone jack.
      • If you are looking at the right side of the device, the headphone jack is located in the mid-upper corner (as shown by the red box).
      • The headphone jack is a black rectangle-like shape.
      Ask FixBot
    6. Archos 5 Headphone Jack Repair: step 6, image 1 of 2 Archos 5 Headphone Jack Repair: step 6, image 2 of 2
      • Cut a small piece of electrical wire that is long enough to reach the ground connectors on each side of the headphone jack.
      • The wire MUST go AROUND the connector for the device to close properly.
      Ask FixBot
    7. Archos 5 Headphone Jack Repair: step 7, image 1 of 2 Archos 5 Headphone Jack Repair: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Hold the electrical wire with tweezers and begin soldering each end of the wire to the two ground connectors.
      • If you do not know how to solder, follow this link to learn how! How To Solder.
      • Do not wait too long while soldering or else you may damage your device.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 37
All Time: 1,282
