Archos 101 G9 Motherboard Replacement
    1. Archos 101 G9 Motherboard Replacement, Display Assembly: step 1, image 1 of 1
      • Place an iFixit opening tool in the crease where the display assembly and back of the device meet.
      • Slide the tool firmly through the crease on one side of the device, twisting as you go to create separation.
      • When you reach the corner, carefully pry the two halves of the device apart.
      • There are small clips along the edges that need to stay intact in order to properly reassemble the device. Be very gentle when prying so as not to break the clips.
      • Repeat for the remaining three sides and corners.
      Ask FixBot
    2. Archos 101 G9 Motherboard Replacement: step 2, image 1 of 2 Archos 101 G9 Motherboard Replacement: step 2, image 2 of 2
      • Separate the halves of the device.
      • Ensure that you separate from the top and you keep the bottoms of both pieces near each other so as not to damage the ribbon cables that connect the halves.
      Ask FixBot
    3. Archos 101 G9 Motherboard Replacement: step 3, image 1 of 2 Archos 101 G9 Motherboard Replacement: step 3, image 2 of 2
      • Gently remove both ribbon cables from their sockets on the motherboard.
      Ask FixBot
    4. Archos 101 G9 Motherboard Replacement: step 4, image 1 of 1
      • Remove the white and black coaxial cables with gold tips from the motherboard.
      Ask FixBot
    5. Archos 101 G9 Motherboard Replacement: step 5, image 1 of 1
      • Remove the display assembly from the back panel.
      Ask FixBot
    1. Archos 101 G9 Motherboard Replacement, Motherboard: step 6, image 1 of 1
      • Remove the 2 mm screw that holds the motherboard in place using a Phillips #0 screwdriver.
      Ask FixBot
    2. Archos 101 G9 Motherboard Replacement: step 7, image 1 of 1
      • Carefully remove the ribbon cable from its socket on the motherboard.
      Ask FixBot
    3. Archos 101 G9 Motherboard Replacement: step 8, image 1 of 1
      • Remove the tape covering all of the solder connections on the motherboard.
      Ask FixBot
    4. Archos 101 G9 Motherboard Replacement: step 9, image 1 of 1
      • Desolder all six of the connections that were underneath the tape.
      Ask FixBot
    5. Archos 101 G9 Motherboard Replacement: step 10, image 1 of 1
      • Remove the motherboard from the tablet.
      Ask FixBot
Clay Meunier
557 Reputation
4 Guides authored
UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021 Member of UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 63
All Time: 640
