Introduction
Using this guide will help you repair the microUSB port in your Archos 101 G9 tablet.
A micro USB port is a miniaturized version of the Universal Serial Bus (USB) interface developed for connecting compact and mobile devices such as smartphones, MP3 players, GPS devices, photo printers, and digital cameras. Micro USB connectors exist or have existed in three forms: micro A, micro B, and micro C. When you get to Step 4 of the guide, it is okay to remove the ribbon cable, but it will make your life easier if you try not to remove the ribbon cable that is attached to the plastic piece.
Place an iFixit opening tool in the crease where the display assembly and back of the device meet.
Slide the tool firmly through the crease on one side of the device, twisting as you go to create separation.
When you reach the corner, carefully pry the two halves of the device apart.
Repeat for the remaining three sides and corners.
Remove the 2 mm screw that holds the motherboard in place using a Phillips #0 screwdriver.
Locate the microUSB port at the bottom of the motherboard.
Remove the rubber piece next to the microUSB port.
